    update 1.3.015
    6 Posts 4 Posters 49 Views 2 Watching
      VectorStyler 1.3.015 release notes
      • Added an option to select search level in Find and Replace (replacing Case Sensitive)
      • Selecting text with Find and Replace to show text options in context panel
      • Added an option to disable ungrouping of clipped groups
      • Added an option to use right click to delete nodes in the path editor
      • Add original file to recent list after Save As
      • Allow selection in node tool when over a selected background object
      • Improved selection of thin shapes over a solid backdrop
      • Fixed a bug in simplifying combined shapes
      • Fixed a bug in sizing imported SVGs
      • Fixed an issue with using Option(Alt)+ hovering in Layers panel for temporary isolation view
      • Fixed an issue in selecting objects witj open paths and contour effects
      • Fixed a ug in dragged objects from the Layers panel
      • Fixed s bug in rendering clipped grpups
      • Fixed a snapping issue at large zoom levels
      • Fixed a transparent gradient rendering issue in 16-bit mode
      • Fixed a bug in noise rendering
      • Fixed a bug in linked image updating
      • Fixed a bug in the Appearance panel UI
      • Fixed a bug in moving layers selected with member layers
      • Fixed a stroke join printing issue on Windows
      • Fixed an issue in exporting overprint option to PDF
      • Fixed a color panel layout issue
      • Fixed a bug in undoing the conversion of text frame to path
      • Fixed a bug in text formatting causing issues with the superscript and subscript
      • Fixed a positioning issue in text to path conversion
      • Fixed a bug in scaling duplicated text shapes
      • Fixed a bug in composite glyph handling of variable fonts
      • Fixed a bug in selecting combined groups
      • Fixed a bug in the conical gradient editor
      BoldlineB debraspicherD 2 Replies Last reply Reply Quote 11
        @VectorStyler Thank you for all the updates and fixes. Much appreciated!
        • debraspicherD Offline
          debraspicher @VectorStyler
          @VectorStyler Very nice and always appreciated!
          32GB RAM @ 6000MHz
          • W Online
            William Kansepa
            @VectorStyler said in update 1.3.015:
            Thank you @VectorStyler. A great update, as per usual.
            Addition number three from the top is as insightful as they come. I am still trying to find out where this option is located?
            • W Online
              William Kansepa @William Kansepa
              Update: I found it under Other Options!
              The challenge is I am failing to get it to work. Am getting same result whether the option is checked or unchecked.
                VectorStyler @William Kansepa
                @William-Kansepa said in update 1.3.015:
                I will test this more. The option name should be "Allow Ungrouping of Clipping Groups"
