<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[update 1.3.015]]></title><description><![CDATA[<h3>VectorStyler 1.3.015 release notes</h3>
<li>Added an option to select search level in Find and Replace (replacing Case Sensitive)</li>
<li>Selecting text with Find and Replace to show text options in context panel</li>
<li>Added an option to disable ungrouping of clipped groups</li>
<li>Added an option to use right click to delete nodes in the path editor</li>
<li>Add original file to recent list after Save As</li>
<li>Allow selection in node tool when over a selected background object</li>
<li>Improved selection of thin shapes over a solid backdrop</li>
<li>Fixed a bug in simplifying combined shapes</li>
<li>Fixed a bug in sizing imported SVGs</li>
<li>Fixed an issue with using Option(Alt)+ hovering in Layers panel for temporary isolation view</li>
<li>Fixed an issue in selecting objects witj open paths and contour effects</li>
<li>Fixed a ug in dragged objects from the Layers panel</li>
<li>Fixed s bug in rendering clipped grpups</li>
<li>Fixed a snapping issue at large zoom levels</li>
<li>Fixed a transparent gradient rendering issue in 16-bit mode</li>
<li>Fixed a bug in noise rendering</li>
<li>Fixed a bug in linked image updating</li>
<li>Fixed a bug in the Appearance panel UI</li>
<li>Fixed a bug in moving layers selected with member layers</li>
<li>Fixed a stroke join printing issue on Windows</li>
<li>Fixed an issue in exporting overprint option to PDF</li>
<li>Fixed a color panel layout issue</li>
<li>Fixed a bug in undoing the conversion of text frame to path</li>
<li>Fixed a bug in text formatting causing issues with the superscript and subscript</li>
<li>Fixed a positioning issue in text to path conversion</li>
<li>Fixed a bug in scaling duplicated text shapes</li>
<li>Fixed a bug in composite glyph handling of variable fonts</li>
<li>Fixed a bug in selecting combined groups</li>
<li>Fixed a bug in the conical gradient editor</li>
]]></description><link>https://www.vectorstyler.com/forum/topic/5749/update-1.3.015</link><generator>RSS for Node</generator><lastBuildDate>Sat, 02 May 2026 07:54:30 GMT</lastBuildDate><atom:link href="https://www.vectorstyler.com/forum/topic/5749.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 30 Apr 2026 17:09:24 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to update 1.3.015 on Fri, 01 May 2026 18:34:57 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/william-kansepa" aria-label="Profile: William-Kansepa">@<bdi>William-Kansepa</bdi></a> said in <a href="/forum/post/33116">update 1.3.015</a>:</p>
<blockquote>
<p dir="auto">Am getting same result whether the option is checked or unchecked.</p>
</blockquote>
<p dir="auto">I will test this more. The option name should be "Allow Ungrouping of Clipping Groups"</p>
]]></description><link>https://www.vectorstyler.com/forum/post/33119</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/33119</guid><dc:creator><![CDATA[VectorStyler]]></dc:creator><pubDate>Fri, 01 May 2026 18:34:57 GMT</pubDate></item><item><title><![CDATA[Reply to update 1.3.015 on Fri, 01 May 2026 15:02:36 GMT]]></title><description><![CDATA[<p dir="auto">said in <a href="/forum/post/33112">update 1.3.015</a>:</p>
<blockquote>
<p dir="auto">Addition number three from the top is as insightful as they come. I am still trying to find out where this option is located?</p>
</blockquote>
<p dir="auto">Update: I found it under Other Options!<br />
The challenge is I am failing to get it to work. Am getting same result whether the option is checked or unchecked.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/33116</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/33116</guid><dc:creator><![CDATA[William Kansepa]]></dc:creator><pubDate>Fri, 01 May 2026 15:02:36 GMT</pubDate></item><item><title><![CDATA[Reply to update 1.3.015 on Fri, 01 May 2026 14:13:17 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/vectorstyler" aria-label="Profile: VectorStyler">@<bdi>VectorStyler</bdi></a> said in <a href="/forum/post/33091">update 1.3.015</a>:</p>
<blockquote>
<p dir="auto">Added an option to disable ungrouping of clipped groups</p>
</blockquote>
<p dir="auto">Thank you <a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/vectorstyler" aria-label="Profile: VectorStyler">@<bdi>VectorStyler</bdi></a>. A great update, as per usual.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/33112</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/33112</guid><dc:creator><![CDATA[William Kansepa]]></dc:creator><pubDate>Fri, 01 May 2026 14:13:17 GMT</pubDate></item><item><title><![CDATA[Reply to update 1.3.015 on Fri, 01 May 2026 02:15:07 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/vectorstyler" aria-label="Profile: VectorStyler">@<bdi>VectorStyler</bdi></a> Very nice and always appreciated!</p>
]]></description><link>https://www.vectorstyler.com/forum/post/33097</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/33097</guid><dc:creator><![CDATA[debraspicher]]></dc:creator><pubDate>Fri, 01 May 2026 02:15:07 GMT</pubDate></item><item><title><![CDATA[Reply to update 1.3.015 on Thu, 30 Apr 2026 19:21:24 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/vectorstyler" aria-label="Profile: VectorStyler">@<bdi>VectorStyler</bdi></a> Thank you for all the updates and fixes. Much appreciated!</p>
]]></description><link>https://www.vectorstyler.com/forum/post/33093</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/33093</guid><dc:creator><![CDATA[Boldline]]></dc:creator><pubDate>Thu, 30 Apr 2026 19:21:24 GMT</pubDate></item></channel></rss>
