    Cloning objects.
    3 Posts 2 Posters 27 Views 2 Watching
    • K Offline
      Kumr
      I created several clones of an object using Option+D. How can I quickly select the original object from the clones? Ideally, I would like to request a right-click popup menu that highlights and selects the original object, or a shortcut key for the same function. Additionally, it would be helpful if there was an option to select all clones in the right-click popup menu.
      Another thing I noticed is that Option+D creates a clone of the created clone, but not of the original object. How can I make clones of only the original object not the created object?
      Perhaps these were addressed already, I couldn’t find them in search.
      Thanks
        Subpath @Kumr
        @Kumr
        I am a bit confused because Option+D usual dont create any clones
        its just duplicate objects. But i guess you have changed the duplicate mode
        to clones.
        +Shift+Ctrl+D at least on windows will create clones.
        Here how to select the original
        Here how to select the clones
        • K Offline
          Kumr @Subpath
          @Subpath @vectorstyler Thanks, was searching for that command. It's mapped under attributes and I was looking elsewhere.
          Couple of things
          I managed to add a menu shortcut using the customize toolboxes, but when I click on the icon, it only displays the attributes popup, and the icons and text description are not right.
          I tried to add a custom shortcut, but it appears as “attribute” instead of being labeled as the cloned or clone, as it was named in the menu. I haven’t tested the shortcut yet.
          I have two objects, one blue and the other magenta, each with its clone. When I select only one cloned object, say blue, the clone command selects parent clones of blue and magenta. Not sure if this is how it’s supposed to work. I would expect to select only blue parent clone only.
          By the way, in Mac, Command+D to duplicate, and Option+D to clone. I don’t recall changing the shortcuts. Perhaps I did, and I need to check on that. 🙂
          Hope cloning of parent object instead of cloned ones could be addressed.
          Thanks.
