    update 1.3.011
    4 Posts 4 Posters 113 Views 4 Watching
      VectorStyler 1.3.011 release notes
      • Added paragraph option for text shaping
      • Improved halftone handling inside distorted groups
      • Added a backdrop color option for halftones
      • Allow expanding halftones inside groups
      • Pick colors with Option(Alt) modifier while in the Gradient tool
      • Fixed a bug in context menu while text is selected
      • Changed the position of brush options in the context panel
      • Allow repeater and halftone expanding inside groups
      • Expanding objects should convert to curves first
      • Keep visible backdrop when expanding repeater
      • Allow Option(Alt)+ select inside mirror and transform groups
      • Select imported graphics
      • Fixed a bug in AI file opening with linked images
      • Fixed a bug in importing mask images with colors from AI files
      • Fixed a bug opening AI files with gradients
      • Fixed a bug in repeaters with visible backdrop
      • Fixed a bug in Layers panel to select objects
      • Fixed a bug in perspective drop shadow
      • Fixed a bug in corner editing
      • Fixed a bug in creating image effect styles
      • Fixed a bug in Shape and Image Effects panel updating
      • Fixed a bug in Clip to Artboards display mode
      • Fixed a bug in in Drop Caps handling
      • Fixed a regression in the node removal tool
      • Fixed a bug in exporting PNG files
      • Fixed a bug in scaling mirror and transform groups
      IngolfI K debraspicherD 3 Replies Last reply Reply Quote 9
        Ingolf @VectorStyler
        @VectorStyler said in update 1.3.011:
        Works again! Thank you so much for the fix! 🙂
        • K Offline
          Kumr @VectorStyler
          Thanks for fixing this. Works now
          • debraspicherD Offline
            debraspicher @VectorStyler
            @VectorStyler Thanks. Will check it out.
            32GB RAM @ 6000MHz
