<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[update 1.3.011]]></title><description><![CDATA[<h3>VectorStyler 1.3.011 release notes</h3>
<li>Added paragraph option for text shaping</li>
<li>Improved halftone handling inside distorted groups</li>
<li>Added a backdrop color option for halftones</li>
<li>Allow expanding halftones inside groups</li>
<li>Pick colors with Option(Alt) modifier while in the Gradient tool</li>
<li>Fixed a bug in context menu while text is selected</li>
<li>Changed the position of brush options in the context panel</li>
<li>Allow repeater and halftone expanding inside groups</li>
<li>Expanding objects should convert to curves first</li>
<li>Keep visible backdrop when expanding repeater</li>
<li>Allow Option(Alt)+ select inside mirror and transform groups</li>
<li>Select imported graphics</li>
<li>Fixed a bug in AI file opening with linked images</li>
<li>Fixed a bug in importing mask images with colors from AI files</li>
<li>Fixed a bug opening AI files with gradients</li>
<li>Fixed a bug in repeaters with visible backdrop</li>
<li>Fixed a bug in Layers panel to select objects</li>
<li>Fixed a bug in perspective drop shadow</li>
<li>Fixed a bug in corner editing</li>
<li>Fixed a bug in creating image effect styles</li>
<li>Fixed a bug in Shape and Image Effects panel updating</li>
<li>Fixed a bug in Clip to Artboards display mode</li>
<li>Fixed a bug in in Drop Caps handling</li>
<li>Fixed a regression in the node removal tool</li>
<li>Fixed a bug in exporting PNG files</li>
<li>Fixed a bug in scaling mirror and transform groups</li>
]]></description><link>https://www.vectorstyler.com/forum/topic/5682/update-1.3.011</link><generator>RSS for Node</generator><lastBuildDate>Fri, 16 Oct 2026 20:35:26 GMT</lastBuildDate><atom:link href="https://www.vectorstyler.com/forum/topic/5682.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 04 Mar 2026 13:14:08 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to update 1.3.011 on Fri, 06 Mar 2026 21:42:48 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/vectorstyler" aria-label="Profile: VectorStyler">@<bdi>VectorStyler</bdi></a> Thanks. Will check it out.</p>
]]></description><link>https://www.vectorstyler.com/forum/post/32813</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/32813</guid><dc:creator><![CDATA[debraspicher]]></dc:creator><pubDate>Fri, 06 Mar 2026 21:42:48 GMT</pubDate></item><item><title><![CDATA[Reply to update 1.3.011 on Fri, 06 Mar 2026 05:14:18 GMT]]></title><description><![CDATA[<blockquote>
</blockquote>
<p dir="auto">Thanks for fixing this. Works now</p>
]]></description><link>https://www.vectorstyler.com/forum/post/32809</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/32809</guid><dc:creator><![CDATA[Kumr]]></dc:creator><pubDate>Fri, 06 Mar 2026 05:14:18 GMT</pubDate></item><item><title><![CDATA[Reply to update 1.3.011 on Wed, 04 Mar 2026 21:44:01 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/forum/user/vectorstyler" aria-label="Profile: VectorStyler">@<bdi>VectorStyler</bdi></a> said in <a href="/forum/post/32797">update 1.3.011</a>:</p>
<blockquote>
<p dir="auto">Pick colors with Option(Alt) modifier while in the Gradient tool</p>
</blockquote>
<p dir="auto">Works again! Thank you so much for the fix! <img src="https://www.vectorstyler.com/forum/assets/plugins/nodebb-plugin-emoji/emoji/android/1f642.png?v=06f033d742e" class="not-responsive emoji emoji-android emoji--slightly_smiling_face" style="height:23px;width:auto;vertical-align:middle" title=":-)" alt="🙂" /></p>
]]></description><link>https://www.vectorstyler.com/forum/post/32804</link><guid isPermaLink="true">https://www.vectorstyler.com/forum/post/32804</guid><dc:creator><![CDATA[Ingolf]]></dc:creator><pubDate>Wed, 04 Mar 2026 21:44:01 GMT</pubDate></item></channel></rss>
