    28 Posts 5 Posters 33.6k Views 5 Watching
    • B Offline
      B-Vs-V @VectorStyler
        VectorStyler @B-Vs-V
        On the other hand, if we do not stretch the shapes (rigid shapes), then they get overlapped.
        If we would keep the whole pattern content rigid (not possible at this time), then the overlapping would get worse.
        I think the best option is that I will try to figure out the difference between what VS does and what is in the example form that AI file. For that it would be great if you could send me the AI file, and would also help in finding the reason for the crash 🙂
        • B Offline
          This is wrong in VS:
          and I don't know how to get it
          I don't have time to go further but every one can try this.
          P.
            • B Offline
              B-Vs-V
              Thanks in advance.
              P.
                • B Offline
                  @vectoradmin Thank you very much for your help and presence on this forum 👍
                    FanVidder @VectorStyler
                      Boldline @FanVidder
                      @FanVidder What task(s) are you trying to complete?
                        FanVidder @Boldline
                        @Boldline actually, I've just found a site containing enough tutorials to get me started. I find the workspace really daunting (I use Illustrator at college and I also have Affinity, but I can't afford Adobe at home). How do I set up my workspace so that all the panels are available? Thanks.
                        I managed to find the Tutorials page on here.
                          Subpath @FanVidder
                          @FanVidder
                          I don't find the basic steps all that complicated. CorelDraw was my main
                          application before VS, i know a few other vector graphic apps too. It took
                          me a while to get used to the new terminology.
                          It might look complicated, and some functions are harder to understand.
                          Just take your time and go step by step.
                          Yes, there aren't many tutorials on YouTube, probably due to the still small
                          user base. I do post tutorials here in the forum from time to time, but I have
                          no interest in dealing with YouTube; it's just too much effort.
                          The best thing to do is search the forum, check out the tutorial section, or simply ask.
