      VectorStyler @monsterfox
      The input box is too small.
      I will fix this.
      • M Online
        monsterfox @VectorStyler
        @VectorStyler https://youtu.be/5DpjF0Ld8vI?feature=shared
        After editing the effect, the parameters cannot be modified; otherwise, it will revert to the unedited state. It is hoped that the parameters can be modified without disrupting the edited form.
          This is a bit problematic. Changing the grid size will reset the mesh grid into its default state.
          I will think of a solution.
          • M Online
            @VectorStyler Cut a shape, create a new canvas, and paste the shape onto the canvas. However, the shape is not in the center of the canvas, and it is hoped that this issue can be optimized.0_1758034901890_mmexport1758033808068.jpg
              @monsterfox When pasting, the position on the new artboard is similar to the position on the original artboard, this is by design.
              • M Online
                @VectorStyler I'm curious about maximizing the display of the current canvas. Theoretically, it should be in the center of the screen, and when we paste a graphic, it should also be in the center of the screen in theory, but there's a deviation. Most vector graphics software don't have this issue. Being able to paste graphics directly in the center of the canvas would save the subsequent steps of moving or aligning them to the center of the canvas. I still hope this problem can be resolved.
                  • M Online
                    @VectorStyler 0_1758464624045_mmexport1758464586186.jpg There are many other functions not listed here. Theoretically, all functions should be supported (except for some feature switches), and it is hoped that they can be fully added in the future.
                      @monsterfox I will try to fix this.
                        @monsterfox Maybe I misunderstood, but the "Connect Paths" action is added to history, at least here.
                        A recording might help explaining the issue.
                        What other actions are not added to the history?
                        • M Online
                          @VectorStyler You got it wrong. This is the Recent panel, not the history.
                            @monsterfox Got it, I will try to replicate with that
                            • M Online
                              @VectorStyler https://youtu.be/DDNwnIYu6Pc?feature=shared
                              https://youtu.be/BF5jP_AjDb8?feature=shared[0_1758984111661_测试.ai](/forum/assets/uploads/files/1758984114074-测试.ai)
                              If there are no grouped graphics in an AI file, copying them into VS will automatically create groups. We discussed this issue before, but I’ve noticed it creates more than one group with different distributions, and the number of groups increases as the number of graphics grows. Can this problem be resolved?
                              Additionally, when any grouped graphics in VS are copied into AI, they disappear automatically. This is another issue that needs to be fixed.
                              VectorStylerV BoldlineB 3 Replies Last reply Reply Quote 1
                                @monsterfox I will try to fix these
                                  Boldline @monsterfox
                                  @monsterfox @VectorStyler i agree that’s it would be nice if vectors opened in illustrator honored grouping. I do like when importing vectors into vs that they are grouped by color but it would be nice if the whole thing was grouped overall and then after the first grouping, it could still be grouped by colors
                                  • M Online
                                    monsterfox @Boldline
                                    @Boldline My requirement is a bit different from yours—I just need to get as close as possible to the group relationship of the original graphic file. Your requirement can actually be easily solved with the Magic Wand Tool combined with panel operations.
                                    • M Online
                                      @VectorStyler https://youtu.be/ZBSGW9rCt74?feature=shared
                                      Export any graphic to SVG format and open the file in Inkscape—you’ll notice the file size has decreased. This is an issue that needs to be resolved.
                                      Proceed to perform a move or ungroup operation, then save the file and import it into VS. You’ll find the graphic now has transform attributes and has grown larger. (If you copy and paste between the two programs repeatedly, the graphic size will also keep getting smaller.)
                                      It is hoped that these errors can be resolved.
                                        I cannot replicate this.
                                        • M Online
                                          @VectorStyler That's strange. I always encounter this problem. Besides, have you tested copying and pasting between these two programs? It also causes the issue of the graphics becoming smaller.
                                            Yes, in both directions. Copying from AI to VS will have some changes, as it goes through PDF and VS will get only what AI exported to PDF (including the clipped groups)
