    list of errors
    46 Posts 2 Posters 33.1k Views 2 Watching
      VectorStyler @monsterfox
      1. With the Magic Wand tool, selecting an internal shape will also select the external shape.
      Enabling the "Intersecting shapes" mode causes this, any shape having a common region (non-empty intersection) with the selected shape is selected
      2. No matter how I try, when I copy the red line to AI, its path is automatically expanded.
      The stroke has the "distorted mode" set, can be turned off with the 6th icon in the Stroke panel.
      I will fix this, as in this case there is no actual distortion.
        An error with the Rounded Corner tool.
        This can be replicated.
        5. Grouping two shapes with 50% transparency yields an unexpected result. Pressing the shortcut key 0 doesn't restore them to 100% solid color. I'm not sure if this is an error.
        This is not a bug. Grouping those shapes keeps the transparency at the object level, not the group level. The group transparency will be 100%.
        The solution is to set the object transparency to 100%, group them, and then set the group transparency to 50%
        • M Online
          monsterfox @VectorStyler
          @VectorStyler The update today didn't fix the bug in the Rounded Corners tool?
            No it did not. For now the corner rounding stops at Cusp node types, even if the node seems to be smooth.
            The attached example can be improved by setting those node types to Smooth (but there will be other issues also).
            I have this issue still open, and will try to improve it later.
            • M Online
              @VectorStyler Moving an object with Ctrl+D, then entering outline mode and pressing Ctrl+D again fails to continue the previous operation step.
                I added this to the backlog
                • M Online
                  @VectorStyler https://youtu.be/Xhj0SgWV6VY?feature=shared
                  0_1753800013754_替换偏移.vstyler The shape selection tool operates normally, but the shape selection function in the menu has a position shifting issue. It is hoped that this problem can be fixed.
                  • M Online
                    @VectorStyler 0_1754145570756_da_1754055731907.ai
                    This AI file cannot be imported.
                      Same here. I will try to fix this.
                      • M Online
                        @VectorStyler https://youtu.be/kc87331fVTw?feature=shared
                        0_1754577330883_偏移数据错误.vstyler
                        No extra operations (especially do not use the magnifying glass); the error in this history record can be copied.
                        • M Online
                          @VectorStyler https://youtu.be/8vY-PU0TpfQ?feature=shared
                          The previous file still has errors. There's no problem when using the graphic selection tool, but when using the graphic selection function in the menu, the selected graphics are offset. This issue still needs to be fixed.
                            @monsterfox Was that toolbar created with a previous version?
                            If so, the action parameter is changed now, so please recreate the toolbar or remove and add the action again.
                            • M Online
                              @VectorStyler You might not have noticed that there's a step in my video where I operate via the menu. Additionally, the same error occurs with the button I re-added. It's important to note the order in which you select the graphics: first click the red one, then the black one.
                              • M Online
                                monsterfox @monsterfox
                                @VectorStyler https://youtu.be/NG9n2eJN1M8?feature=shared
                                0_1755269768694_4点5.vstyler
                                • M Online
                                  @VectorStyler https://youtu.be/ema-3fKkLcA?feature=shared![0_1755442541826_mmexport1755442255412.jpg](/forum/assets/uploads/files/1755442544054-mmexport1755442255412-resized.jpg)
                                  • M Online
                                    @VectorStyler https://youtu.be/2tymaMPgsp0?feature=shared
                                    https://youtu.be/-1idSoMPKSY?feature=shared[0_1755787575851_测试+1.vstyler](/forum/assets/uploads/files/1755787578727-测试-1.vstyler)
                                    Video 1: When using the shape selection function, displacement still occurs. However, if they are converted to curves and then this function is used, most shapes are normal, while a small number still have offsets. If the shape selector tool is used, none of the above problems exist.
                                    Video 2: A special error occurs. Some of the lines in it do not change.
                                      @monsterfox I will try to fix these.
                                      • M Online
                                        @VectorStyler I wonder if you have tested with the file I provided. Currently, the error in shape selection still persists, and it seems somewhat difficult to resolve.
                                          @monsterfox Yes I tested it. If you try to overlap the two shapes they are different, that causes the small relative movement between the parts of the shape.
                                          Is there some other error I'm not aware of?
                                          • M Online
                                            @VectorStyler said in list of errors:
                                            So far, the only issues found are the two mentioned in my video.
