Is it possible to suppress a Shape Effect via a Shape/Mask Role ?
 Is there a way to suppress a Shape Effect via a Shape/Mask Role ?
 If yes which role should be used ?For Example i have a few Lines with a Shape Effect applied in this case
 a outline zigzag Shape Effect. But i would like the area below the
 letter to be flat.In the image I used a clipping mask with the letter. But I thought
 having a way to suppress a shape effect would offer further
 possibilities.
 @Subpath No possible for this effect. A few effects use a mask for intensity, but not in this case
 Thank you, I just wanted to know. I know that you can control
 the intensity of some effects using a mask.
 @Subpath Is it the effect like in the video?
 https://youtu.be/BULN1fvnBt0
 Yes ! Wow! I am very impressed.
 Looks like you use some Data magic to suppress the Waves ?
 Would you mind to show how you does it ?Btw. i got the Idea for this from this Cavalry Video.
 https://www.youtube.com/watch?v=h9ubkXrlToQ
 @Subpath Last year, I used a similar effect in a design draft, so with some modifications, I can achieve the effect you want. I will take some time to record the operation method and post it in the tutorial section.
 @Li-Xiao said in Is it possible to suppress a Shape Effect via a Shape/Mask Role ?: I will take some time to record the operation method and post it in the tutorial section. That would be great; I'm sure other users would
 like learn a few tricks from it too.Take your time. I'm not in a hurry.
 Thank you for stopping by.
 @Subpath
 I used displacement effect for this. I will find some time in the next few days to record it.
