    Is it possible to suppress a Shape Effect via a Shape/Mask Role ?
    8 Posts 3 Posters 4.0k Views 3 Watching
      Is there a way to suppress a Shape Effect via a Shape/Mask Role ?
      If yes which role should be used ?
      For Example i have a few Lines with a Shape Effect applied in this case
      a outline zigzag Shape Effect. But i would like the area below the
      letter to be flat.
      In the image I used a clipping mask with the letter. But I thought
      having a way to suppress a shape effect would offer further
      possibilities.
      VectorStylerV L 2 Replies Last reply Reply Quote 1
        VectorStyler @Subpath
        @Subpath No possible for this effect. A few effects use a mask for intensity, but not in this case
          Subpath @VectorStyler
          Thank you, I just wanted to know. I know that you can control
          the intensity of some effects using a mask.
          • L Online
            Li Xiao @Subpath
            @Subpath Is it the effect like in the video?
            https://youtu.be/BULN1fvnBt0
              Subpath @Li Xiao
              @Li-Xiao
              Yes !
              Wow! I am very impressed.
              Looks like you use some Data magic to suppress the Waves ?
              Would you mind to show how you does it ?
              Btw. i got the Idea for this from this Cavalry Video.
              https://www.youtube.com/watch?v=h9ubkXrlToQ
              • L Online
                Li Xiao @Subpath
                @Subpath Last year, I used a similar effect in a design draft, so with some modifications, I can achieve the effect you want. I will take some time to record the operation method and post it in the tutorial section.
                  Subpath @Li Xiao
                  @Li-Xiao said in Is it possible to suppress a Shape Effect via a Shape/Mask Role ?:
                  That would be great; I'm sure other users would
                  like learn a few tricks from it too.
                  Take your time. I'm not in a hurry.
                  Thank you for stopping by.
                  • L Online
                    Li Xiao @Subpath
                    @Subpath
                    I used displacement effect for this. I will find some time in the next few days to record it.
