      monsterfox
      @VectorStyler Strictly speaking, this is an error. When using the Direct Selection Tool and the Node Tool on an unclosed path, the results displayed in the Path panel are different, which needs to be fixed.!2_1750950034005_mmexport1750948282437.png 1_1750950033992_mmexport1750948280840.png 0_1750950033981_mmexport1750948278018.png
        VectorStyler @monsterfox
          monsterfox @VectorStyler
          @VectorStyler Draw two shapes, A and B. Group them together. Use the selection tool to select shape A and press Ctrl+D (duplicate in place). The newly generated shape will be grouped together with A and B. This logic is incorrect; it should be independent instead. It is hoped that this issue will be fixed.
          E VectorStylerV 2 Replies Last reply Reply Quote 1
          • E Online
            EricP @monsterfox
            @monsterfox I don't think this logic is incorrect.
            Duplicate a member of a group, the copy belongs to that group. Affinity works the same way
              monsterfox @EricP
              @EricP I'm using Freehand, and it follows the same logic as I described. Having the in-place duplicated shapes grouped together is For example, if I need to offset the path of the newly generated shape, being in a group reduces flexibility and makes the process feel restrictive.
                Dont know whats the right or best one in this case.
                Just wondering that Corel Draw keep a duplicated shape
                of a group ( using CTRL D) also in the Group.
                Whereby using CTRL C and CTRL V put that Shape
                outside of a group, in VectorStyler and Corel Draw.
                  This is a bit problematic. Currently any duplication will be done inside the same Layer / Group as the source.
                  But there could be an option in the future to control this.
                    @VectorStyler https://youtu.be/9ZGx038Sd6w?feature=shared
                    The Contour cannot be preset, so it has to be reset every time you use it, which is very troublesome.
                    VectorStylerV M 2 Replies Last reply Reply Quote 1
                        monsterfox @monsterfox
                          @VectorStyler 1. When using the offset tool effect, it cannot be converted to a curve.
                          2. For the individual transformation functions, rotation and stretching can all take effect based on their own coordinates, but mirroring does not work with the original coordinates. It is hoped that this function can be optimized.
                          https://youtu.be/GjPcbM1yNQI?feature=shared
                              @VectorStyler It seems that clicking the eraser tool to erase the graphic isn't working.
                                @monsterfox Can you show a recording? Also what is the icon of the tool? (there are multiple different eraser tools).
                                And an example file (could be something with the shape).
                                  @VectorStyler https://youtu.be/QABT2hjyjZs?feature=shared
                                    I cannot replicate this, I need that file from the recording.
                                      @VectorStyler 0_1754404481232_擦除.vstyler
                                        @VectorStyler https://youtu.be/hq_XGUYcn1g?feature=shared
                                        When blending two graphics, in Freehand, you can select one of the graphics and then select "Parent" to choose the blended graphic. However, VS does not yet have this function, and we hope it can be added.
                                          @monsterfox The problem here is that in VS the starting - blend - ending objects are 3 separate objects. They can be grouped, but that is a separate action.
                                          Selecting the parent of one ending will not select the blend as it is not the parent.
                                            @VectorStyler 0_1754664178907_重复效果.vstyler
                                            In the operation process, I mostly use shortcut keys for most functions. When I open the Effects panel, I notice several duplicate effects, specifically the 4-point effect and the Transform effect. I'm not sure if this is by design, but at least the Transform effects should be mergeable.
                                            I had already applied the 4-point effect and added some other effects afterward. When I tried to continue using the 4-point effect via the shortcut key, it created a new instance instead of continuing the operation on the existing one, resulting in several duplicate effects. Is it possible to merge them?
