    • DanielD Offline
      Daniel @Subpath
      @Subpath: You can use + numpad key to stamp copies in XD.
        VectorStyler @Daniel
        XDP manages remarkable rendering speed
        Interesting, but almost all these are also done in VS, of course details matter.
        I suspect they also have some low-level trick, since moving that amount of pixels (including composition) has its limits.
        • DanielD Offline
          Daniel @VectorStyler
          @VectorStyler: Xara developers are very tight lipped about their techniques. So I can't get more information than that. My question is how Xara is able to apply complex 16-bit FX, often piling them on top of one another, and yet maintain the fluidity and speed it is known for. It's one of the few software that actually manages to balance speed, performance and quality. I'll see if I can get more intel for you.
          What do you mean by low-level tricks? You mean tricks at the level of assembly code? or something else?
            Subpath @Daniel
            Indeed, this work with my copy too
            • DanielD Offline
              Daniel
              All the feature and ideas are now captured in XLS.
                Boldline @Subpath
                @Subpath said in XLS for features and ideas - Mega Thread:
                Pressing the + key does have a certain logic.
                However, I wanted to suggest using the "Spacebar" for this,
                Would this interfere with the panning ability the spacebar already uses?
                  @Boldline said in XLS for features and ideas - Mega Thread:
                  Not really, the panning is started while the mouse is released, this one would work while the mouse is pressed and objects (symbols) are dragged.
                    Subpath @Boldline
                    no, as @VectorStyler wrote
                    you could try it yourself, select a Shape hold it and drag it around
                    nothing is happen when you press the spacebar
                    to copy a shape/shapes this way you press the spacebar once
                    at the place you want them to be, but holding your first shape still
                    with the Mouse
                    • DanielD Offline
                      Daniel
                      @VectorStyler: Auto Extend Lines for slicing: This is a very useful extension of slice Boolean operation. I use this to really quickly slice shapes. Say I want to diagonally slice a square. I don't need to draw an entire line across the square. Just the tiniest line in the middle at an approximate 45-degree angle would do. I then select both and slice. Voila, it's done. The logic is simple. The line is always interpreted to end at the closest 15-degree increment. For example, if I placed a line at 40-degree, the line is extended at 45-degree during the slicing operation. If I place it 32-degree, the line is extended at 30-degree and so on. Not only can this happen for straight lines, but even for complex curves. The line is always extended. An example of meaningful pre-empting of user intent. 🙂 https://imgur.com/a/IODAlqL
                      Source: XDP.
                        Interesting combination of features. I think this is easy to add. Does it work for any curve?
                        In VS you can extend a shape to the next intersection with another (selected) shape, using the Trim and Join tool, with holding Alt.
                        And then you can use Cut as a shape operation.
                        • DanielD Offline
                          @VectorStyler: works for any open curve.
                          • DanielD Offline
                            Daniel
                            Drag and drop color from swatch onto object with FX to change the colour of the FX. For example, drag and drop color to shadow to change color of shadow. Drag and drop color to the contour to change the contour colour. Etc.
                              Yes, but what tool is selected for this to happen? If the tool used to edit that effect is selected, then this is doable.
                              But in the default transform tool, this might be an issue.
                                Subpath @Daniel
                                @Daniel
                                Well, personally I don't see any real reason to use drag & drop to color objects
                                Whats your reason, or user case, for that ?
                                  VectorStyler @Subpath
                                  It is possible to color objects with drag&drop in VS,.
                                    Subpath @VectorStyler
                                    @VectorStyler said in XLS for features and ideas - Mega Thread:
                                    Thanks, interesting to know, but I don't remember ever using it.
                                    I've seen it in other programs i use, but I always found it a bit cumbersome.
                                    • DanielD Offline
                                      Daniel @Subpath
                                      @Subpath: it's incredibly useful and fast if correctly implemented. It allows you to change contrast of fx without cumbersome sliders.
                                      • DanielD Offline
                                        @VectorStyler: it is the default transform tool but with modifier.
                                          That is problematic, because then we don't know which effect / property is selected.
                                          • DanielD Offline
                                            @VectorStyler: How about then simply selecting the FX first in the yet-to-be-developed properties panel? Before the drag and drop?
