    • DanielD Offline
      Daniel @Subpath
      @Subpath both inkscape and corel copied it from xdp.
        Subpath @Daniel
        @Daniel
        what does "xdp" mean ?
        • DanielD Offline
          Daniel @Subpath
          @Subpath: Xara Designer Pro. 🙂
          • DanielD Offline
            Daniel
            @VectorStyler 17 Crystallographic groups for tesselation and pattern work. At the moment, you can create these pattern groups by manipulating square, triangular and rhombus patterns, but they should be available straightforwardly. Illustrator does this through a plugin. Inkscape does it directly. https://en.wikipedia.org/wiki/Wallpaper_group - Here are the wallpaper groups and their mathematics.
              Subpath @Daniel
              autsch, i should know that 🙂
              yes, inkscape can also copy via spacebar
              my copy of Xara Designer not
              ( is not a Pro Version )
              • DanielD Offline
                Daniel
                Feedback in continuation of the thread started on FX customisation and speed of rendering, found in the general discussions category.
                @VectorStyler: Found this useful summary of how XDP manages remarkable rendering speed. I can't fully understand the technical aspect of it. But I get the user experience side of it. However, thought you might be able to make sense of it better than me. Here it is:
                Optimization Techniques
                Xara employs several optimization strategies:
                • Just-in-time rendering - Only visible portions of the document are fully rendered, saving processing power.
                • Object-level display lists - Rather than regenerating the entire screen, Xara tracks which objects need redrawing.
                • Hierarchical spatial indexing - Advanced data structures that quickly determine which objects are in the visible area.
                • Incremental updating - When changes are made, only affected areas are recalculated rather than the entire document.
                • Direct rendering - Can display complex document elements without conversion steps.
                • Multi-threaded processing - Utilizes multiple CPU cores effectively for parallel processing.
                Memory Management
                • Intelligent caching - Frequently accessed elements are stored in memory for quick retrieval.
                • Memory-mapped file access - Allows direct access to file data without requiring full loading into RAM.
                • Efficient memory allocation - Custom memory management reduces fragmentation and overhead.
                • DanielD Offline
                  Daniel @Subpath
                  @Subpath: You can use + numpad key to stamp copies in XD.
                    VectorStyler @Daniel
                    Interesting, but almost all these are also done in VS, of course details matter.
                    I suspect they also have some low-level trick, since moving that amount of pixels (including composition) has its limits.
                    • DanielD Offline
                      Daniel @VectorStyler
                      @VectorStyler: Xara developers are very tight lipped about their techniques. So I can't get more information than that. My question is how Xara is able to apply complex 16-bit FX, often piling them on top of one another, and yet maintain the fluidity and speed it is known for. It's one of the few software that actually manages to balance speed, performance and quality. I'll see if I can get more intel for you.
                      What do you mean by low-level tricks? You mean tricks at the level of assembly code? or something else?
                        Subpath @Daniel
                        Indeed, this work with my copy too
                        • DanielD Offline
                          Daniel
                          All the feature and ideas are now captured in XLS.
                            Boldline @Subpath
                            @Subpath said in XLS for features and ideas - Mega Thread:
                            Pressing the + key does have a certain logic.
                            However, I wanted to suggest using the "Spacebar" for this,
                            Would this interfere with the panning ability the spacebar already uses?
                              @Boldline said in XLS for features and ideas - Mega Thread:
                              Not really, the panning is started while the mouse is released, this one would work while the mouse is pressed and objects (symbols) are dragged.
                                Subpath @Boldline
                                no, as @VectorStyler wrote
                                you could try it yourself, select a Shape hold it and drag it around
                                nothing is happen when you press the spacebar
                                to copy a shape/shapes this way you press the spacebar once
                                at the place you want them to be, but holding your first shape still
                                with the Mouse
                                • DanielD Offline
                                  Daniel
                                  @VectorStyler: Auto Extend Lines for slicing: This is a very useful extension of slice Boolean operation. I use this to really quickly slice shapes. Say I want to diagonally slice a square. I don't need to draw an entire line across the square. Just the tiniest line in the middle at an approximate 45-degree angle would do. I then select both and slice. Voila, it's done. The logic is simple. The line is always interpreted to end at the closest 15-degree increment. For example, if I placed a line at 40-degree, the line is extended at 45-degree during the slicing operation. If I place it 32-degree, the line is extended at 30-degree and so on. Not only can this happen for straight lines, but even for complex curves. The line is always extended. An example of meaningful pre-empting of user intent. 🙂 https://imgur.com/a/IODAlqL
                                  Source: XDP.
                                    Interesting combination of features. I think this is easy to add. Does it work for any curve?
                                    In VS you can extend a shape to the next intersection with another (selected) shape, using the Trim and Join tool, with holding Alt.
                                    And then you can use Cut as a shape operation.
                                    • DanielD Offline
                                      @VectorStyler: works for any open curve.
                                      • DanielD Offline
                                        Daniel
                                        Drag and drop color from swatch onto object with FX to change the colour of the FX. For example, drag and drop color to shadow to change color of shadow. Drag and drop color to the contour to change the contour colour. Etc.
                                          Yes, but what tool is selected for this to happen? If the tool used to edit that effect is selected, then this is doable.
                                          But in the default transform tool, this might be an issue.
                                            Subpath @Daniel
                                            @Daniel
                                            Well, personally I don't see any real reason to use drag & drop to color objects
                                            Whats your reason, or user case, for that ?
