Greyed Menu Items
No, it doesn't, I have to restart VS.
@fdarnel I will try to figure out the root cause for this.
@fdarnel About the cmd+1: a workaround for now is to customize the shortcuts, and reassign manually this shortcut.
I'm curious, if you reassign the shortcut for cmd+1 (so that it works as zoom 1:1) will that gray the menus.
@VectorStyler said in Greyed Menu Items:
Where to customize the shortcuts?
@fdarnel Application Menu -> Keyboard Shortcuts
Well, I changed for Command-& in the setting, it works, but is now referenced as Command-7 in the View menu.
@fdarnel said in Greyed Menu Items:
I will try to sort this out. The cmd+1 in the French layout is the cmd+ampersand, which is cmd+7.
I will try to sort these things out. BTW: there is also a UI translation planned before 1.3
OK, at least it works. If you need some help for translation.
I will notify later on this for beta testing.
@fdarnel are there any other ways (besides the cmd+1) to get to this Greyed menus. I'm still trying to replicate it
It seems to be when using some shortcuts, not sure if it's only with cmd-1.
Hi, still the same behavior with the last version.
@fdarnel I still could not replicate this. Also tried on MacOS 15.3.1
