    Pencil tool defaults back to a black stroke (instead of "no-stroke")
    12 Posts 3 Posters 9.5k Views 2 Watching
      I've quit VS and reopened it to a fresh document and the issue remains. I also reset the settings back to default and the issue remains. No matter how many times I turn off the black stroke and just have the fill active, the pencil tool reverts back to giving me a fill and stroke each time
      If there's a specific setting I need to adjust, let me know.
      0_1734786815160_9af3a9c1-f6c5-4ac7-98a6-4ac88256baf0-BLD 2024-12-21 at 08.13.21.png
      šŸŽ macOS Tahoe 26.2, Mac mini (M1, 2020), Chip Apple M1, Memory 16 GB
        monsterfox
        @Boldline You need to save the settings as another and replace your current settings.
          @Boldline I will try to replicate this.
            Boldline @monsterfox
            @monsterfox I appreciate your input, but I'm not understanding fully what you mean. I have a saved custom settings preset I use that has the "Filled shapes with pencil tool" active already. It still insists on keeping the stroke active
              @VectorStyler I noticed when I try to use the pencil tool with fill only - it auto switches away from the color that was already in the active fill box in the context menu. It's also choosing two different blacks - one for the fill and a different one for the stroke.
              Here is a link to a video showing this
              I tested this with a fresh document on my intel mac running the build 52 and it worked just fine. When I then updated it to the newest build 54, it was not working correctly for me. I don't know if something related to the pencil tool changed from build 52 to build 54?
                @Boldline The root cause of the problem is identified now, the fix will be in the next build.
                Meanwhile, as a workaround, check the Angle of the pencil head in the Pencil tool options, it should be zero.
                  @VectorStyler I’m so glad you were able to find the cause of the issue and fix it! I’m impressed. Thank you for that
                    @VectorStyler said in Pencil tool defaults back to a black stroke (instead of "no-stroke"):
                    Where would I check the angle of the pencil head?
                    0_1735584832924_6c4206e7-c39e-4155-a4b1-335ce6942417-BLD 2024-12-30 at 13.53.35.png
                      @Boldline In the current stroke options (stroke panel icon bar, first button), the angle should be zero.
                      (I was wrong about the place).
                        @Boldline THis angle issue will be fixed in the next build.
                          @VectorStyler ok. Mine was already set to zero and the issue remained. Is that expected?
                            @Boldline said in Pencil tool defaults back to a black stroke (instead of "no-stroke"):
                            Is that expected?
                            Yes
