update 1.2.052
VectorStyler 1.2.052 release notes
- Fixed a regression in clipped group expanding.
- Fixed a bug in OpenType contextual substitution and position handling.
- Added a new path blending mode (for Blend effect), suitable for aligning and blending open paths.
- Tablet stylus will not retain brush style by default.
- Added tablet stylus pressure control curve option (in tool options accessed with double click).
- Fixed a crash when exporting slices from iconified panel.
- Fixed the cursor size and position of empty distorted text.
- Default snapping options of a new document to be the last selected options.
- Fixed an editing preview issue with the node editor in outline preview mode.
- Show grid margins option of the palette panel is global now for all color palette panels.
- List tiling pattern content presets with pattern styles.
- Default noise position to be relative mode in effects and brushes.
- Fill style shortcuts to work for outline mode also.
- Improved number field scrolling in Appearance panel.
- Number field slider to align with the knob.
- Changed the Arrange Artboards view layout.
- Shape combination operations of the Path panel to be active for single groups also.
- Improved crossing gap handling for composite paths.
- Better default options selection in Stroke and Brush panels.
Thank you for the quick fix of the tablet stylus pressure sensitivity and the addition of the pressure control curve option.
Thank you @VectorStyler, as always
