update 1.2.050
VectorStyler 1.2.050 release notes
- Added node snapping to pen and line drawing tools.
- Fixed a bug in tracking text with hyphenation.
- Improved text breaking mode around special characters.
- Added a name for the § key.
- Fixed a crash when accessing keyboard shortcut editor from the shortcut.
- Direct preview mode in pencil tool should allow shape redrawing.
- Default scaling mode should be relative in repeated transform.
- Added a notification when deleting in global color palettes (that are saved to an external file).
- Allow drag and drop of data files into the Data Sources panel.
- Apply brush tint to images inside vector brush.
- List all opened color palettes in colorizer filter.
- Deleting the last node should delete the object.
- Fixed a bug when deleting multiple segments in one step.
- Allow parent object selection when editing nodes.
When editing a node, the selection of the father fails, and the result is deselection.
Well, I have lost count of the number of times I have been
amazed at the pace of your updates. Just impressive as always.
@monsterfox said in update 1.2.050:
Can you show me how to replicate this? If I edit an object clipped into an other object, the "Select Parent" will select the parent, but of course the clipped object is not selected anymore.
This is by design (move selection up in the hierarchy).
@Subpath said in update 1.2.050:
amazed at the pace of your updates. Just impressive as always.That is indeed jaw dropping remarkable speed in reporting a few bugs and getting a fix for them literally within a couple of days. Is this developer on steroids or something?
... Is this developer on steroids or something? ...
indeed he isI wondered often how something like this is possible.
Especially when you consider how long other graphic program developers
need for less than half fixes and VectorStyler is one developer.I think he knows his stuff inside and out.
Which is also reflected in the program’s wide range of features.
https://youtu.be/AqPYe5N_ZEw?feature=shared
The father of the node is this path, and the father of the path is the group (or compound path) together with the circle. Then, it increases level by level in turn until the final level of this object is reached. Only such logic is reasonable.
@VectorStyler Thank you very much for the node snapping! You are the best. Would it also possible to have an option/or enable this when using the node tool?
@Zero said in update 1.2.050:
I can add an option for this, it was actually disabled because it did not look very good.
I think this is what happens in VS also.
@VectorStyler But this operates with different effects. The father of the node is not the path. It has been cancelled. It needs to be verified on your side.
