SVG import pixel to point conversion
@Ayo said in SVG import pixel to point conversion:
How does this work in Vectorstyler import SVG?
It should be 1 px to 1 pt. Is the file opened or imported?
Send me an example file where this occurs.
Opening or importing > placing makes no difference.
For example
Specified > VS- river lines are 1 pixel > 0.2 pt
- lat/lon gridlines is 0.5 pixel > 0.1 pt
- coastline is 2 pixel (half buried under land cover) > 0.5 pt
By email VS file and original SVG TINYMAP
EDIT:
The earlier mentioned wrong type size value display also occurs in this file.
Specified 6pt > VS 25 pt -
@Ayo I opened the file in VS, AI and Affinity and all gave the same line width of 0.239 pt.
What is the version of AI you used?
@VectorStyler said in SVG import pixel to point conversion:
If it should be 1:1, they are all wrong. Or is there some other mysterious ratio behind it?
Or an example of copying and pasting SVG code snippets that can replicate bugs across multiple applications?
Yes, this would help if you have such an example.
I also opened the file in Inkscape and it reports 0.241 pt stroke width.
@Ayo Found the cause, it is not a bug.
The SVG header sets a "viewBox" scaling and all apps (including VS) will scale accordingly.
Workaround: in VS, after opening the file, select all and select Effects -> Remove All Shape Effects.
This will remove all viewbox transforms, it will also remove the y-flip depending if it was opened or imported (SVG and VS cordinate directions are different) so you may need to flip the drawing vertically.
Hmm... quite complex.
If I do that, artwork is indeed flipped AND becomes about 4x bigger. Then scale everything back 24% to original size. Stroke weights are fine then. You would think that the type point size should also be fine with this trick, but it remains 25 pt. Scaled or not. -
This is a different issue.
Yes, the problem is that I cannot ignore what is in the SVG header, otherwise it is not a correct import.
And the SVG header scales from a viewBox into a width/height that is different. -
Yes, the problem
Got it... (a little)
Remember that the problem can also be on the other side. In other words; the SVG output of Qgis can also contain imperfections or errors.Still strange that ai6 does work against all common opponents. I wonder what Freehand would do but I don't have that working under the buttons anymore.
Thanks for investigating
