about choice
@monsterfox I could not replicate the selection issue from the first image. This might be a caused by some selection settings (I have the default settings here).
@VectorStyler said in about choice:
A file I provided above. You can have a try.
@monsterfox I tried with the file: https://share.cleanshot.com/3DdbdYYF
@VectorStyler You try this graphic in size 38.
@monsterfox Tried all, same result.
@VectorStyler It's a bit strange. The test results today are different from yours.
@monsterfox This could be caused by some settings related to how the selection works.
@monsterfox said in about choice:
Can you send me the file, containing only the drawing from where the box selection selects the outer shape also.
Could be that we are testing with a different version of the file.
@VectorStyler I've found the problem. This is because the graphic is a filled and unclosed graphic that the outer shape can be selected. Unfilled unclosed paths will not be selected.
In this mode, the graphics below the color cannot be selected.
@monsterfox Send me that file.
