about choice
@VectorStyler https://youtu.be/QpAvcIyHdnU?feature=shared Currently, it seems that it is not possible to frame-select within the graphic, which will cause the outline to be selected together, but the several red graphics are exceptions.Hope to be able to frame-select without selecting the outline. Please fix it, thank you.
@monsterfox said in about choice:
I will try to fix this for the next build.
0_1727362577735_3_1.vstyler
For the first picture, when choosing the inner shape, the outer lines are still selected. It is found that this is not a closed line. If it were a closed line, it would not be selected. I hope this problem can be fixed. For the second picture, the black line represents the original position of the shape. Use the shape replacement tool on the left, with the black letters above as the target source. After replacement, the original shape will be offset, which is the position of the red line. I hope these two problems can be fixed together. Thank you.
I will try to fix these.
@monsterfox I could not replicate the selection issue from the first image. This might be a caused by some selection settings (I have the default settings here).
@VectorStyler said in about choice:
A file I provided above. You can have a try.
@monsterfox I tried with the file: https://share.cleanshot.com/3DdbdYYF
@VectorStyler You try this graphic in size 38.
@monsterfox Tried all, same result.
@VectorStyler It's a bit strange. The test results today are different from yours.
@monsterfox This could be caused by some settings related to how the selection works.
Can you send me the file, containing only the drawing from where the box selection selects the outer shape also.
Could be that we are testing with a different version of the file.
@VectorStyler I've found the problem. This is because the graphic is a filled and unclosed graphic that the outer shape can be selected. Unfilled unclosed paths will not be selected.
In this mode, the graphics below the color cannot be selected.
@monsterfox Send me that file.
