    Gradient Editor
    16 Posts 4 Posters 14.3k Views 4 Watching
      VectorStyler @debraspicher
      @debraspicher said in Gradient Editor:
      The dragging behavior has not helped with that experience and it's something I wish I could disable
      I will make this optional.
        Subpath @debraspicher
        @debraspicher
        The question of whether it's my fault or a bug in VectorStyler
        is probably one of the questions that users have most often in
        their minds. Which is not meant maliciously.
        It took me also a while to understand the operating concept and
        I was actually able to cope with many vector graphics programs
        before that. But over time, the confusion gradually cleared up.
        But despite all that, VectorStyler is my main vector graphics program
        and I wouldn't want to be without it.
        • L Online
          Li Xiao @Subpath
          I have also used many vector graphic programs, but the way VectorStyler operates is very suitable for me. I hardly need to consult the manual, and it feels like I have been using the program for a long time. Some of the concepts in it are just what I have always dreamed of.
            Subpath @Li Xiao
            @Li-Xiao
            Yes, some tools were easier to understand than others. I remember coming
            from CorelDraw and not being able to figure out how to turn an artist brush into
            a shape in VectorStyler.
            Here my very first post.
            https://www.vectorstyler.com/forum/topic/844/new-user-i-stuck-with-a-simple-thing
            • debraspicherD Offline
              debraspicher @VectorStyler
              @VectorStyler Sometimes it misses those single clicks but can go for long runs without an issue. It's better since you made adjustments to the fields.
              @Subpath said in Gradient Editor:
              @debraspicher
              I'm tolerant to UX differences in programs if the implementation is predictable, so it's no problem for me that VS is different. For the most part I've adjusted fine and am adapting to the VS way of doing things just fine. In this case, it's a matter of the interface behaving fine at some points, misbehaving at others and stubbornly refusing to take input at others.
              For example.. visibility and lock icons rarely register when I click on them in Layers panel. Sometimes I can use single-click to rename a Layer, but most of the time I can't do this properly. This means I have to pull up dialogs and sometimes those inputs can be finicky individually. It really depends on which input. So while the solution can be "more UI" and "add this preference item", I think when the UI is glitchy and isn't taking input and behaving as intended, that's the root cause of 90% of the issue. (by issue, I mean specifically "frustration")
              It's not consistent behavior/misbehavior so it is hard to learn a "intended" workflow(s) if it keeps responding out of spec. Add to this, more confusion when I don't know what "in spec" even is as a new user, especially when trying to pick up new tools for the first time.
              This video was a fantastic example of that experience and other oddities that can happen because of weird panel behavior. I didn't know whether "single" or "double" click was meant to get the Gradient color pop up or not, for example, because it wasn't appearing. I had thought maybe I even hit a modifier key or a shortcut that caused that and maybe I was just imagining that panel that appeared for a split second...
              Other issues I'm having, some of which I've reported, but others I'm still trying to collect because there's so many little things. Ctrl + ; (show/hide) guides doesn't work. Keyboard shortcuts related to zoom, especially anything to do with canvas elements, don't take and it can take like 8-10 times before it finally does take. There's lots of little things like this, but I'm not trying to clutter the board and I'm also making sure that it's not just growing pains and yes, that field item or toggle totally ignored my mouse input (again).
              I say this to say not that VS is "bad", but that my setup is clearly experiencing some issues with the interface above average. So much so, I'm debating nuking this copy of Windows and just starting over. Something I've been considering lately anyway because I was also debating an upgrade.
              32GB RAM @ 6000MHz
              VectorStylerV 1 Reply Last reply Reply Quote 4
                @debraspicher I will try to improve the number field handling.
                  debraspicher
                  I have another video with other possibly new bugs. A few issues (mostly in order):
                  1. I can't edit the node positioning, however occasionally it will drop random (new) positions.
                  2. At about @0:06 in the video I go to activate the second node to remove it and it both removes itself and creates a new swatch in the middle. This creates a Cyan swatch in the center. This is interesting because this swatch was used in the Sky Object above it and was one of the last swatches I worked with before moving to this Object. It could also be that I activated the Sky wrongly and then went to select the Ground object and it remembered this selection. It did let me delete that swatch, but I had a lot of trouble deleting others. Either way, I lost my original color scheme upon deleition, so I had to undo.
                  3. There is a point where I can haphazardly create other Cyan swatches in the middle portions of the Gradient, but I can't activate those to work with them.
                  4. The swatches themselves are difficult to find and click due to the percentage label overlapping them.
                  5. Note also, the percentage labels are appearing at strange locations and in some cases are delayed in following the mouse as I drag. (The red circle indicators when I'm clicking or dragging with the mouse). Sometimes when I click, the percentage label would be offset a bit, but it's harder to see in the video.
                  6. Periodically the cyan swatch likes to remake itself and apply itself to the center. The Cyan swatch is probably a leftover from working with the Sky object before this one, but why it would remember that swatch and try to apply it here, I'm not really sure. I could've selected the Sky Object right before starting this gradient and it may have been kept it from then.
                  Link: https://1drv.ms/v/s!AuWHX0h5bAoRipIZ-wPKfBK_8JiiuA?e=xLIrMt
                  Gradient is unusable in this particular state. But I might've figured out at least part of what was happening. It's possible when I am making single/double clicks to activate the color flyout, it is creating swatches underneath the 1st swatch rather than allowing me to access the swatch node to pull up the Color picker. This seems to be the case as when I try to edit the 1st swatch, I'll occasionally see a sliver of the color I'm working with in the picker instead of the true 1st swatch, like I intend:
                  Closer up:
                  I considered maybe because I had the Transform Tool active instead of the Gradient editor, it was causing a problem, but it didn't seem to help. I did check the Gradient Editor at one point in the toolbar. This is just a video showing another unread click event on this machine (sometime after @0:22). Note the red circle showing click events and trying to hold to get it to appear. The Mesh one above works fine, but it takes a moment for the Gradient editor flyout to respond:
                  https://1drv.ms/v/s!AuWHX0h5bAoRipIa23R01mkHH-qlbw?e=Q5TcGz
                  It is possible to edit Gradients in this file as intended and even get the Color flyout to appear when working with the Gradient swatches, but it can't be when an Object is selected in this instance and it can't be an Object having any kind of issue if I want to recolor it using the [Color]Panel (not the flyout).
                  I made a recording of this kind of behavior. It shows I can't work with the original problem gradient. Even switching to Transform and deselecting Objects and going back to the Gradient Editor, that particular gradient is still non-responsive. So I select a new gradient from the Preset dropdown and work with it directly. It won't let me edit a swatch from the Color Panel, however the flyout now works so I can use that instead. As if that isn't crazy-making enough, I accidentally apply a new gradient to the original problem Object and hit Undo to restore the bad gradient. Now I can edit the original problem gradient just fine (it seems):
                  https://1drv.ms/v/s!AuWHX0h5bAoRipIbWl9CaJk7P9ejJA?e=Ihnmo1
                  I will send the file directly.
                  32GB RAM @ 6000MHz
                    debraspicher
                    Posting to show that the "out of bound" swatch problem still occurs even if we can color things fine and move swatches freely across the rest of the gradient.
                    When I move the swatch to the very left border, I can't access it again and so I lose that swatch seemingly for good:
                    https://1drv.ms/v/s!AuWHX0h5bAoRipIcmjVjm6HmnNuNiw?e=2Dzk3P
                    Edit: I did discover it's possible to access these when using Gradient tool and zooming in and viewing the swatches on the Gradient editor line itself.
                    32GB RAM @ 6000MHz
                      @debraspicher I opened a new bug on these issues. The problem is caused by that round (oval) transition knob between the gradient positions.
                        @VectorStyler Yeah I've been able to still work with it using the gradient line. Sometimes it "unmucks" the UI also and allows me to work with it through the Gradient Editor panel. But largely using the line now.
                        The only "problem" I have with using the line is that when I do use the color panel fly out, it's sometimes blocking elements so I can't see what it is actually doing. That's the only real downside.
                        32GB RAM @ 6000MHz
