VS clipboard being overwhelmed
When trying to copy (via clipboard) complex artwork or huge images to another document, VS becomes overwhelmed and actually freezes occasionally.
Looks like the clipboard is lagging behind the other wonderful features. Could you please look into this?
Thank you.
@William-Kansepa When copying to the clipboard, a PDF "export" is also copied, and this might take time for complex documents.
It is possible to disable PDF copying by unchecking Settings -> Importing -> Copy as PDF
@VectorStyler said in VS clipboard being overwhelmed:
It is possible to disable PDF copying by unchecking Settings -> Importing -> Copy as PDFI have unchecked the setting and the challenge still persists. I was copying a 300dpi image measuring 100cm x 125cm into another document.
At one point VS crashed.
@William-Kansepa I will try to replicate this.
