    Regarding the halftone repeater types
    76 Posts 6 Posters 204.6k Views 4 Watching
    • L Online
      Li Xiao @VectorStyler
      https://www.vectorstyler.com/forum/assets/uploads/files/1711824219187-offset-halftone-fill-vs.pdf
        VectorStyler @Li Xiao
        @Li-Xiao Is there a vstyler file for this? or was this done in an other app?
        • L Online
          @VectorStyler said in Regarding the halftone repeater types:
          It was done by another app. I have tried it with VS, but even version 1.2.019 cannot do it.
            @Li-Xiao
            Can be done, requires a few steps: 0_1712857903612_repeaterfile4.vstyler
            • define a number variable "offset" of type "Number Slider", set the min/max to -0.6/0.6 and its value to 0.
            • add the Offset Path effect to the "VS" text (offset should be small).
            • set the offset distance to the "offset" variable (control+click on the distance number field and select "offset").
            • create the repeater (offset is constant now).
            • in the repeater panel menu, select "Adjust Number Values".
            • select "offset" in Number and check the "Adjusted Number"
            • set the Adjustment to "Object Content" and min/max to -0.5/0.5 (can use other values to different effect), confirm this.
            • now what happens is that the "offset" number variable will vary using the background intensities between -0.5 and 0.5
            But the good news is: this can be done with number variables and number fields with any effect, property etc in repeaters.
            • L Online
              @Li-Xiao
              Using number variables in combination is a good approach, but mapping a single element to a grayscale value alone is not sufficient. Please take a look at the example.
                @Li-Xiao yes, this is not yet possible. The offset must be the same in an object.
                L 2 Replies Last reply Reply Quote 0
                • L Online
                  Yes, that's correct. Currently, the offset feature does not support mapping to grayscale values.
                  I tried using the contour tool and manually expanded it by dozens before using the Repeater, but after several hours of attempts, I didn't achieve any results. I forgot to try using offset with variables.
                  • L Online
                    Block-like Halftone
                    Mondrian is generated by a VBA macro in CorelDraw.
                    Unable to generate within Repeater.
                    0_1713458482635_Mondrian.pdf
                    https://en.wikipedia.org/wiki/Piet_Mondrian
                    Recursion Halftone
                    Also fails to generate within Repeater
                    https://www.flickr.com/photos/village9991/2198931517/
                    https://discourse.mcneel.com/t/quadtree-or-recursion-with-image-sampler/125758
                    https://www.artmajeur.com/alzon/en?view=grid
                    https://www.josephandjames.com/alzon
                      @Li-Xiao These will be fore later versions
                      L 2 Replies Last reply Reply Quote 1
                        @Li-Xiao
                        Found a little Program made with Processing
                        which offers Circle Packing and a few other Styles
                        Results can be saved as SVG
                        https://ehufsted.itch.io/halftonepal
                        Here a Result imported in VS
                        • L Online
                          Li Xiao @Subpath
                          @Subpath
                          Thank you! I used to use StippleGen (https://wiki.evilmadscientist.com/StippleGen) and HalftonePal before, but I haven't used them since I purchased DrawingBot. DrawingBot includes all the features of both of them. Kumiko (https://kumiko-generator.netlify.app/) is also interesting, DrawingBot is unable to replicate its effects.
                            Subpath @Li Xiao
                            @Li-Xiao
                            thank you too, for the links
                            and also for all of your interesting Ideas 👍
                              @Li-Xiao
                              Btw. I was following an Idea in Nodebox and it seems i came to a Solution
                              where you can replace a Shape in an .SVG File with any Shape you like.
                              Even with Text.
                              I used the Circle Packing .SVG from my post above and replaced the circle
                              with the text “Flower”.
                              Import in VectorStyler works via exporting as .PDF from Nodebox
                              and then import the .PDF in VectorStyler
                              (.SVG does not work)
                              Here a Example
                              Here the Nodebox Tree:
                              A short explanation of the Nodes
                              "Slice" will pick the Shape
                              "Centroid" calculate the Center of the Shape (Result is the Position)
                              "fit_to" fits the size of the Shape (Text) into the Size of the Circle
                              "rotate" allows to rotate the Text
                              • L Online
                                Li Xiao @Subpath
                                @Subpath Thank you, I will try Nodebox when I have time to see if it can create more unique designs.
                                The 1.2.019 update now allows me to create several other halftone styles that I wanted to submit.
                                Repeater is indeed powerful.
                                However, there is still room for improvement in terms of space filling and sorting.
                                  Subpath @Li Xiao
                                  @Li-Xiao
                                  ...The 1.2.019 update now allows me to create several other halftone styles that I wanted to submit....
                                  You already have a curious viewer waiting 🙂
                                  • L Online
                                    Li Xiao @Subpath
                                    @Subpath
                                    I'll showcase a Modulation Halftone, primarily controlling the dots and lines or edges of shapes corresponding to grayscale values. The example features a circular shape with adjustments made to the effects of 8 nodes. In order to attract more people to purchase VectorStyler, I haven't recorded the complete production process. If you're interested, please send me a private message, and I'll record a complete tutorial and send it to you privately.
                                    0_1713537685839_Modulation Halftone 2.svg
                                    https://go.screenpal.com/watch/cZfq2yVMVKY
                                    M S 2 Replies Last reply Reply Quote 2
                                      monsterfox @Li Xiao
                                      @Li-Xiao 你玩这些东西玩的很溜啊。好多东西,我以前都没有见过。
                                        Subpath @Li Xiao
                                        @Li-Xiao
                                        Thanks for your offer. Since I'm not in a hurry, it won't be a problem for me
                                        if you find the time sometime later to do a little tutorial in the tutorial section
                                        on how to create such designs in the repeater.
                                        Until then, I will continue to follow this thread with interest and welcome
                                        your ideas for improving and expanding the repeater.
                                        • L Online
                                          @VectorStyler "Maze patterns" are great, but "Maze halftone" is less common. The ones I've seen are usually just a Maze pattern with added stroke width effects, rather than utilizing grayscale variations. hope VS can incorporate both "Maze" and "Maze halftone" functionality.
                                          0_1714543234552_Maze Halftone.pdf
                                          Reference:
                                          MazeGenerator can generate mazes online for free. It offers four different shapes and three styles. Commercial use requires need a commercial license.
                                          https://www.mazegenerator.net/Default.aspx
                                          Maze Creator has four versions, with the free version only offering two styles.
                                          http://www.mazecreator.com/maze_creator_download_free.php
                                          • L Online
                                            There doesn't seem to be any way to achieve reaction-diffusion halftone within the Repeater. So, I'm gathering some information to see if it's included in the roadmap. Repeater lacks halftone types related to morphogenesis, such as TSP and Voronoi etc.
                                            I really like Reaction-diffusion halftone, and I have purchased some software specifically for creating it. There are two excellent ones, namely Stochaster and TexTuring. Additionally, there are some free options available. Let me introduce one that I particularly like to use. Repeater is powerful, if it's support for Reaction-diffusion halftone, it offers access to a wide range of capabilities that many other software programs simply cannot match.
                                            Stochaster
                                            https://www.stochaster.org/stochaster.html
                                            https://www.youtube.com/watch?v=zc9oOXGqH1Y
                                            TexTuring
                                            https://ivan-murit.fr/project.php?w=texturing
                                            sources available on GitHub (https://github.com/ivangrozny/TexTuring)
                                            https://player.vimeo.com/video/145301542?title=0&byline=0&portrait=0
                                            0_1714907844655_TexTuring-1.svg
                                            0_1714907968338_TexTuring-2.svg
                                            Stochaster offers more features but lacks support for vector export, while TexTuring has fewer features but supports vector export (PDF, SVG). They have some differences and similarities in terms of functionality.
                                            https://www.stochaster.org/talk.html
                                            https://ivan-murit.fr/project.php?w=texturing&p=texturing_stochaster_en.htm
                                            I really like this online open-source reaction-diffusion tool:
                                            https://github.com/jasonwebb/reaction-diffusion-playground
                                            https://jasonwebb.github.io/reaction-diffusion-playground/app.html
                                            Here are some websites for reference:
                                            https://github.com/jasonwebb/morphogenesis-resources?tab=readme-ov-file#reaction-diffusion
                                            https://ferkeltongs.livejournal.com/32025.html
                                            https://en.wikipedia.org/wiki/Reaction–diffusion_system
                                            https://www.karlsims.com/rd.html
                                            https://github.com/gollygang/ready?tab=readme-ov-file
