    A symmetrical figure, rotated by an unknown angle. How to adjust the angle to normal level? Or how to measure the angle of two anchor points?
    33 Posts 5 Posters 48.5k Views 4 Watching
      This might be related to the original question. Is there a shortcut to easily reset the rotation of the selection box to exactly 90 degrees?
      Another helpful feature to add if not already in place is the ability to copy an angle from one share and rotate a text box or other share to match that same angle.
      • L Online
        Li Xiao @monsterfox
        @monsterfox
        It's very easy to do. Please watch the recorded video for reference.
        recorded video
        BoldlineB M 2 Replies Last reply Reply Quote 3
          Boldline @Li Xiao
          @Li-Xiao That is a good solution.
          @VectorStyler what about an option to find the angle between two nodes by selecting any two nodes and seeing the angle amount?
            @Boldline said in A symmetrical figure, rotated by an unknown angle. How to adjust the angle to normal level? Or how to measure the angle of two anchor points?:
            Currently this is only possible if the two nodes are the ends of the same segment, in the Path panel there is an angle option for this.
            @monsterfox Check out the tangential snapping option also.
              monsterfox @Li Xiao
              @Li-Xiao This method is feasible, similar to Freehand's operation. But the accuracy is not enough. I need to keep the exact value to three decimal places (at least two places). I don't know if there is any place to set it up?
                monsterfox @VectorStyler
                @VectorStyler The angle accuracy between the two capture points is not enough, and 3 decimal places need to be retained.
                  @VectorStyler By the way, I have a question. A year ago, I posted a question asking, when can multilingualism be supported? A year has passed now. Can I hear good news?
                  • L Online
                    Li Xiao @monsterfox
                    @monsterfox Application Menu \ Edit \ Settings (Ctrl + ,) \ Decimal Widths
                      VectorStyler @monsterfox
                      @monsterfox said in A symmetrical figure, rotated by an unknown angle. How to adjust the angle to normal level? Or how to measure the angle of two anchor points?:
                      There is no translation yet, but the good news is that there will be by 1.3.
                        It is possible to set the number displayed decimals in the Settings -> Decimal Widths section.
                          monsterfox @Li Xiao
                          @Li-Xiao Thank you for your answer, Seeing your name, I feel that we are from the same country.
                          • L Online
                            Li Xiao @monsterfox
                            @monsterfox You are welcome.
                            Yes, seeing the Chinese text in your file, I think we are from the same country. VS is an amazing software with numerous innovations. You can recommend it to your friends. There is currently a 50% off! making it highly cost-effective. In terms of functionality, it is incredibly affordable.
                              monsterfox @Li Xiao
                              @Li-Xiao 这款软件足够优秀,比市面上的所有软件都强大。但我是用中文的,英文我看太懂,靠翻译交流,包括学习软件,很吃力。如果有中文版,我一定会够买。问了版主,他说要 1.3 版本才会有中文。只能等了,估计要一年 ……
                              • L Online
                                Li Xiao @monsterfox
                                大部分操作并不难,我下个月开始会抽时间录一些基础的视频,用中文标注。
                                  monsterfox
                                  那就要感谢你的付出了。你也是这个论坛的管理员吗?
                                    monsterfox @Li Xiao
                                    @Li-Xiao 因为软件是英文的,我甚至连什么地方设置快捷键都找不到,很痛苦啊😱
                                    • L Online
                                      Li Xiao @monsterfox
                                      不是,我买了VS,希望更多的人用VS
                                      如果你有使用其他软件的经验,界面是不是英文并不重要,很快就能上手的
                                        monsterfox @Li Xiao
                                        @Li-Xiao 我用freehand9.0超过10年,虽然软件是英文的,但是我学习的时候有人教,所以上手并不复杂。但VS确实功能太强大了。Ai , Cdr, Inkscape(前年开始关注到,但目前还不够流畅卡顿明显)我刚才说的几款软件都不如VS强大。所以要是没有中文版的话,学习起来会很吃力。
                                        • L Online
                                          Li Xiao @monsterfox
                                          你用过这么多矢量软件再用VS肯定没问题的,我最初不需要看说明文档就能直接用VS了,感觉像是用了很久的软件一样
                                            monsterfox @Li Xiao
                                            @Li-Xiao 一些基础功能我也很容易上手,但也有一些基础功能是其他软件所没有的。所以还需要摸索一些时间。还有一些高级功能,我现在甚至连门槛都还没有入。顺便问一下,你到时候把教程发论坛什么位置?还是说你也会抖音发一下,给我的账号,提前关注 。
