    VS startup time
    28 Posts 4 Posters 35.5k Views 3 Watching
    • 861475_VctSt8 Offline
      861475_VctSt
      VS startup time
      This is on my main old Macintosh.
      I don't remember when exactly this started.
      It now takes about 1 minute and 30 seconds to start up VS.
      My Macintosh should be maintainable.
      On another M2 Macintosh, it takes about a few seconds to start.
      Where is the problem?
      I have ver1.1.xxx and 1.2.xxx beta coexisting.
      LIc. 0 OS10.15.8
      LIc. 1 OS15.7.4
        VectorStyler @861475_VctSt
        @861475_VctSt said in VS startup time:
        How many fonts you have on the old mac installed in the system?
        This is the only step where VS could be slow at startup.
        Is the slow startup by 1.1 or 1.2?
          861475_VctSt
          Sys: 90
          Lib: 257
          user: 125
          Others are controlled by the 'RightFont' font management utility.
          I don't know how many there are, but I think there are several hundred or more registered.
          In volume: RightFont library: 3.27GB
          Both 1.1xx and 1.2xx take longer to start.
          LIc. 0 OS10.15.8
          LIc. 1 OS15.7.4
            @861475_VctSt How many fonts are on the system where VS starts faster?
              861475_VctSt @VectorStyler
              Sys>Lib>Fonts has 90 fonts.
              There are 257 in Lib>Fonts.
              User>Me>Lib>Fonts has 125.
              Should I specify the font folder in Setting?
              LIc. 0 OS10.15.8
              LIc. 1 OS15.7.4
                @861475_VctSt In the ~/Library/Application Support/NumericPath/VectorStyler1.2/vector/data/ folder there is a config.ini file.
                This file contains some low level configuration for the app, including how to handle fonts at startup.
                Can you send me the file by email?
                  Roger.
                  I will attach it in the mailer.
                  Best regards.
                  LIc. 0 OS10.15.8
                  LIc. 1 OS15.7.4
                    @861475_VctSt Got the file. So it seems that at startup, all fonts installed in the system are scanned by VS (fetching basic font info).
                    This might include fonts installed by font managers, as these are seen by apps as fonts from the system.
                    One thing to try is to temporarily disable the font manager and those fonts in the User and Lib folders (keep the 90 fonts of the system) and see if it affects the startup time.
                    I will think of a solution for this.
                    861475_VctSt8 3 Replies Last reply Reply Quote 0
                      Thanks.
                      I will try your suggestion as far as I can.
                      LIc. 0 OS10.15.8
                      LIc. 1 OS15.7.4
                        In Settings>Application, I removed the following settings and it started in 1 minute 15 seconds. 15 seconds faster.
                        Scan Fonts with Host
                        Scan Fonts at Startup
                        Preview Fonts in Lists
                        Later, I will try some more things.
                        Thanks
                        LIc. 0 OS10.15.8
                        LIc. 1 OS15.7.4
                          As you suggested, I tried I could with the user settings.
                          The result was about 1m10s.
                          I was able to shorten my time slightly from 1m30s.
                          I tried it with the old VS1.0.062 in the same environment.
                          It started up in 7 seconds.
                          VS is growing. On the other hand, with my old Macintosh, should I give up on the ``former startup time (7 seconds)''?
                          LIc. 0 OS10.15.8
                          LIc. 1 OS15.7.4
                            @861475_VctSt I will look into this issue, as there is nothing added to the startup that should slow it down.
                            There is one other thing that might cause slowdowns, the Apple notarization process (code signing of the application) might have been changed over the years. This might also impact startup.
                              fde101 Global Moderator
                              I thought the notarization checks were done as part of the Gatekeeper checks at first launch and not after that?
                                VectorStyler @fde101
                                @fde101 Yes it should be. I will try to make the same tests on a similar Mac.
                                  @861475_VctSt One other thing to try: completely remove the user data folder of VectorStyler from ~/Library/Application Support/NumericPath/
                                    @fde101
                                    I deleted that folder.
                                    This will still take 90 seconds. No change.
                                    I'll try to find out when this happened by tracing the VS version (1.2β).
                                    I will try it after I finish my main work, so it will take some time.
                                    addition
                                    The same goes for 1.2.016.
                                    LIc. 0 OS10.15.8
                                    LIc. 1 OS15.7.4
                                      @861475_VctSt Yet another suspect for the slowdown: there might be too many files in the temporary files folder.
                                      This folder unfortunately is hidden in MacOS and it is different per system.
                                      VectorStyler scans the content of this folder for files that might have been created in previous runs (in case of crashes) to avoid accumulating such files.
                                        Temporary files are about this.
                                        /private/tmp
                                        With VS ver. 1.0.062 it starts up in 7 seconds, but with ver. 1.0.005 and later it takes about 90 seconds.
                                        Then I would think, in layman's terms, that there must have been something between these versions "regarding startup". What do you think?
                                        Of course, I'm thinking "maybe it's time for Catalina to retire".
                                        LIc. 0 OS10.15.8
                                        LIc. 1 OS15.7.4
                                          Yes that would be a correct assumption.
                                          But I also tested both 1.2016 and 1.1062 on a MacBook Mid 2012 with Catalina on it. And both start up around 7 seconds.
                                          So I suspect that there might be something here that can be fixed.
                                          BTW: that temp folder is not the one used by apps (temp folders are served by MacOS, and have long /generated names).
                                            Thanks for all your help and research.
                                            I logged in as a different user and started VS1.2 in 7 seconds.
                                            There seems to be a problem with the main account library.
                                            For now, I will continue to use it as is.
                                            Just to be sure, I did the following maintenance on the main account.
                                            Still, the VS startup time did not change.
                                            Deleted the cache here. ( /Users/hara/Library/Caches/TemporaryItems )
                                            Rebuilt the Spotlight data.
                                            Thanks
                                            LIc. 0 OS10.15.8
                                            LIc. 1 OS15.7.4
