    VS startup time
    28 Posts 4 Posters 35.5k Views 3 Watching
    • 861475_VctSt8 Offline
      861475_VctSt @VectorStyler
      As you suggested, I tried I could with the user settings.
      The result was about 1m10s.
      I was able to shorten my time slightly from 1m30s.
      I tried it with the old VS1.0.062 in the same environment.
      It started up in 7 seconds.
      VS is growing. On the other hand, with my old Macintosh, should I give up on the ``former startup time (7 seconds)''?
      LIc. 0 OS10.15.8
      LIc. 1 OS15.7.4
        VectorStyler @861475_VctSt
        @861475_VctSt I will look into this issue, as there is nothing added to the startup that should slow it down.
        There is one other thing that might cause slowdowns, the Apple notarization process (code signing of the application) might have been changed over the years. This might also impact startup.
          fde101 Global Moderator
          I thought the notarization checks were done as part of the Gatekeeper checks at first launch and not after that?
            VectorStyler @fde101
            @fde101 Yes it should be. I will try to make the same tests on a similar Mac.
              @861475_VctSt One other thing to try: completely remove the user data folder of VectorStyler from ~/Library/Application Support/NumericPath/
                @fde101
                I deleted that folder.
                This will still take 90 seconds. No change.
                I'll try to find out when this happened by tracing the VS version (1.2β).
                I will try it after I finish my main work, so it will take some time.
                addition
                The same goes for 1.2.016.
                LIc. 0 OS10.15.8
                LIc. 1 OS15.7.4
                  @861475_VctSt Yet another suspect for the slowdown: there might be too many files in the temporary files folder.
                  This folder unfortunately is hidden in MacOS and it is different per system.
                  VectorStyler scans the content of this folder for files that might have been created in previous runs (in case of crashes) to avoid accumulating such files.
                    Temporary files are about this.
                    /private/tmp
                    With VS ver. 1.0.062 it starts up in 7 seconds, but with ver. 1.0.005 and later it takes about 90 seconds.
                    Then I would think, in layman's terms, that there must have been something between these versions "regarding startup". What do you think?
                    Of course, I'm thinking "maybe it's time for Catalina to retire".
                    LIc. 0 OS10.15.8
                    LIc. 1 OS15.7.4
                      @861475_VctSt said in VS startup time:
                      Yes that would be a correct assumption.
                      But I also tested both 1.2016 and 1.1062 on a MacBook Mid 2012 with Catalina on it. And both start up around 7 seconds.
                      So I suspect that there might be something here that can be fixed.
                      BTW: that temp folder is not the one used by apps (temp folders are served by MacOS, and have long /generated names).
                        Thanks for all your help and research.
                        I logged in as a different user and started VS1.2 in 7 seconds.
                        There seems to be a problem with the main account library.
                        For now, I will continue to use it as is.
                        Just to be sure, I did the following maintenance on the main account.
                        Still, the VS startup time did not change.
                        Deleted the cache here. ( /Users/hara/Library/Caches/TemporaryItems )
                        Rebuilt the Spotlight data.
                        Thanks
                        LIc. 0 OS10.15.8
                        LIc. 1 OS15.7.4
                          None of these are the problem. The temp folder for apps in MacOS are given by an API called "NSTemporaryDirectory"
                          For me this is: /var/folders/05/z_3lq3qx1r3fwq25d68vr6g00000gp/T/
                          But a lot of other apps place their data in this folder.
                          If the content of the folder is too large then VS startup may take longer.
                            /private/var/folders/6y ( mk, nt, zz )
                            I manually removed one by one the 0 capacity folders in each of the 6y, mk, nt, and zz folders.
                            Not all were deleted, but quite a few were reduced.
                            The ones in zz are highly dangerous, so I backed up and deleted only the ones I thought I could delete.
                            As a result, the rainbow cursor spun up in 55 seconds and VS took 60 seconds to boot up.
                            I then used TinkerTool Systemu and CleanMyMac to delete as much cache as I could in the mac.
                            One last question that remains is why only VS 1.1 and above takes so long?
                            I have over 100 other apps installed and none of them take this long.
                            LIc. 0 OS10.15.8
                            LIc. 1 OS15.7.4
                              I think at some point I added a temp file cleanup for startup to avoid VS temp files to accumulate due to crashes.
                              This searches the temp folder and removes files that were created by VS.
                              But this is very easy to disable of course.
                                Thank you very much.
                                Ver. 1.2.018 started up in 7 seconds.
                                I have spent dozens of hours maintaining the machine by myself to no avail.
                                I ask for the sake of layman's education, can you tell me what you did to improve it?
                                LIc. 0 OS10.15.8
                                LIc. 1 OS15.7.4
                                  It does not search for past VS temporary files for cleanup when starting.
                                    In ver. 1.2.107 there was always an old cache here.
                                    /private/var/folders/6y/bplb4gnn2w76qclj0bgpf1f80000gn/C/com.vectorstyler/com.apple.metal
                                    That seems to be the temporary being cached.
                                    CleanMy Mac can now also delete it as system junk.
                                    I am now free from the frustration of starting VS.
                                    Thank you so much.
                                    LIc. 0 OS10.15.8
                                    LIc. 1 OS15.7.4
                                    H 1 Reply Last reply Reply Quote 1
                                    • H Offline
                                      Harry @861475_VctSt
                                      @VectorStyler Where are the temporary files located in Windows?
                                      Should we manually delete them to maintain a clean system since build 1.2.018 doesn't search them?
                                        VectorStyler @Harry
                                        @Harry said in VS startup time:
                                        It is up to the operating system to serve the temporary file locations and this may vary between versions.
                                        VS will still clean the temporary files, but it does so after crashes, and not at startups.
                                        With normal exit, VS will not leave temporary files.
