beta 1.2.013
Found the issue a fix will be uploaded soon.
@VectorStyler Between reading Harry's message and testing on my computer, VectorStyler reports that the problem has been found. Never the less, for what it is worth, I installed 1.2.013 on my Mac Studio M2 Ultra running macOS 14.3.1 and after testing half a dozen keyboard shortcuts there were no problems.
I'm currently getting an error when I try to upgrade, I assume @VectorStyler is replacing the build?
@Harry Uploaded the fix, it affected the Windows version only. Thanks for notifying, and please try again.
@Boldline Try again, yes it was an update of the files.
@VectorStyler said in beta 1.2.013:
Success! thank you
Thanks! It works now!
@VectorStyler I can't test text blocks on one of my files. As soon as I click on a block VS crashes. You must have received at least 5 crash reports and I'm sending you the file, just to let you know
@Pat Got the file. Double clicking the guideline causes the crash. I will fix this ASAP.
Double-clicking on the four corners
The entire text frame is shrunk.https://recordit.co/sqSTbCH2F0
I wonder if my settings are bad.
macOS Catalina 10.15.7
MacBookAir5,2 (13-inch, Mid 2012)
1.8 GHz Dual-Core Intel Core i5
8 GB 1600 MHz DDR3
Intel HD Graphics 4000 1536 MB
@861475_VctSt said in beta 1.2.013:
There is a bug in this new frame fitting feature. First you should resize a bit the text frame and then use the double click.
The bug is already fixed and the fix will be in the next build.
Thanks.
I was able to confirm the issue.
I'm holding on to this for a while.
@Harry Foud the issue a fix will be uploaded soon.
@VectorStyler I'm having this problem (notably with ctrl+z) and I understand that the problem has been fixed, but VS doesn't report any updates. Do I have to install VS manually?
Is a new update due soon, in which case I can wait.
Thanks
@Pat You need to download and install manually, the version was not incremented for this fix.
