What is the most accurate and easy way to slice this type of shape?
Hello,
I was attempting to to divide this tri-shape along the dotted lines
The only way that seemed quick enough was to use the Knife Tool with the shift key held down so it cuts a straight line. Unfortunately the starting and end points of the cut is not precise. I was hoping there was a way to snap the tool to the desired starting and end node. I tried turning on the snapping but it appears that the Knife Tool does not snap when the snap settings are set to 'Snap to Points'.
- Is there a way to get the knife to do precision cuts?
- Is there a faster, more accurate method to divide any shape at the nodes/points, to result in two closed shapes?
Thanks!
recording: https://recordit.co/qlDHnwZbCs
steps:
- enable snap to points
- draw three lines
- select all and divide
@VectorStyler Thank you! I don't know why I wasn't thinking of the combine operations for this. I appreciate the reminder!
