    trapezoid
    18 Posts 7 Posters 14.9k Views 6 Watching
    • B Offline
      B-Vs-V @Subpath
      @Subpath said in trapezoid:
      I'm missing more of a Shape Library Panel
      Where you can insert and remove your shapes using drag and drop.
      This way you could store shapes you've created once
      and put them back on the canvas when you need them again
      A Panel like this could also be helpful for a kind of kitbashing
      @Subpath I thought this feature was already there in VS. I await the next update impatiently so that I can get to work with VS again.
        VectorStyler @Subpath
        You can create shape presets with the Presets panel. Then select those shapes to replace some shape in the canvas.
        (I will also add drag&drop creation).
        S 861475_VctSt8 L 3 Replies Last reply Reply Quote 4
          Subpath @VectorStyler
          @VectorStyler said in trapezoid:
          remember that, but be able to use drag and drop
          would be a little more fluid
          the idea it self came from the app "Concepts"
          on my iPad, here a sketch how it works in Concepts
          just for inspiration
            Boldline @Subpath
            @Subpath The solution "concepts" uses seems like a very effective solution. What do you do if you have many more unique shapes? There seems to be a limit to what can be shown in that layout example you shared
              Subpath @Boldline
              @Boldline said in trapezoid:
              The maximum of that storage fields visible on the screen are 12, on my iPad Pro 12.9.
              The maximum number of shapes is higher because you can switch between different libraries.
              For architecture, electronics, shoes, faces, etc.
              Since scrolling on the iPad is fast and smooth, scrolling back and forth isn't
              much of a problem
              Saving a shape only takes one click,
              also just one click to place a shape on the canvas (or drag & drop).
              So using this shape storage is also pretty fluid.
              • B Offline
                B-Vs-V @Subpath
                @Subpath I could be mistaken, but isn't that also the case for the Affinity suite (assets)?
                  I'm creating a thread in " Features and Ideas. " on this topic,
                  because it is a bit more extensive as I thought.
                  So, my Post about a Shape Library is now in "Features and Ideas"
                  Here the Link:
                  https://www.vectorstyler.com/forum/topic/3878/kind-of-shape-library
                    Subpath @B-Vs-V
                    @Pat
                    I think there are some similarities.
                    • 861475_VctSt8 Offline
                      861475_VctSt @VectorStyler
                      I am sure everyone agrees on how to draw trapezoids using VS's advanced functionality.
                      I think that since there are "star" and "spiral" tools, there should be a "trapezoid" tool as well. I think this is a short-sighted idea.
                      I wonder if this kind of tool is already obsolete.
                      LIc. 0 OS10.15.8
                      LIc. 1 OS15.7.4
                      • L Online
                        Li Xiao @VectorStyler
                        @VectorStyler It is necessary to add a tool that can generate precise irregular polygon shapes, including isosceles triangles, trapezoids, etc. This tool should allow parameterized inputs for different side lengths, angles, and other properties.
                          @861475_VctSt , @Li-Xiao
                          could the "Envelope Distortion" be helpful
                          with this kind of Transformation ?
                          See Video here
                          • L Online
                            Li Xiao @Subpath
                            @Subpath Thank you! I need to generate a correct triangle based on the known values of its three sides, as shown in the following diagram.
                              Subpath @Li Xiao
                              @Li-Xiao, your welcome
                              looks like a CAD case to me ?
                              • L Online
                                Li Xiao @Subpath
                                @Subpath Yes, it is relatively easy to implement in CAD software. Apps like AI or CD have plugins available for generating such shapes.
