    trapezoid
    18 Posts 7 Posters 14.9k Views 6 Watching
    • 861475_VctSt8 Offline
      861475_VctSt
      What steps do you take when drawing a trapezoid?
      Please let me know how to do it in as few steps as possible.
      In the future, I would like to have a trapezoid tool.
      It should be in Transform.
      I would like to develop it further and have an effect to give perspective to the object.
      LIc. 0 OS10.15.8
      LIc. 1 OS13.6.7
      Devil DinosaurD S 2 Replies Last reply Reply Quote 1
      • Devil DinosaurD Offline
        Devil Dinosaur @861475_VctSt
        @861475_VctSt
        I draw a rectangle,
        then I convert it to curve (right click),
        then I select the 2 nodes on the top,
        then I use the scale tool (or change the width value in the transform panel if I need a specific size).
        I agree that a trapezoid tool or readymade shape would be nice.
        Fred.
          Subpath @861475_VctSt
          @861475_VctSt
          here also a description from me 🙂
          Freehand:
          create a rectangle
          convert it to curve
          select the two upper nodes
          switch to transform Tool
          hold ctrl (win) while move the Nodes
          With the Transform Panel:
          create a rectangle
          convert it to curve
          change the Value in the width Field
          ( with Up and Down Keys
          or with the Mouse - Scrollwheel
          or just typing )
          Here a video
            Because of adding other shapes
            I'm missing more of a Shape Library Panel
            Where you can insert and remove your shapes using drag and drop.
            This way you could store shapes you've created once
            and put them back on the canvas when you need them again
            A Panel like this could also be helpful for a kind of kitbashing
            B VectorStylerV 2 Replies Last reply Reply Quote 1
            • B Offline
              B-Vs-V @Subpath
              @Subpath said in trapezoid:
              @Subpath I thought this feature was already there in VS. I await the next update impatiently so that I can get to work with VS again.
                VectorStyler @Subpath
                You can create shape presets with the Presets panel. Then select those shapes to replace some shape in the canvas.
                (I will also add drag&drop creation).
                S 861475_VctSt8 L 3 Replies Last reply Reply Quote 4
                  Subpath @VectorStyler
                  @VectorStyler said in trapezoid:
                  remember that, but be able to use drag and drop
                  would be a little more fluid
                  the idea it self came from the app "Concepts"
                  on my iPad, here a sketch how it works in Concepts
                  just for inspiration
                    Boldline @Subpath
                    @Subpath The solution "concepts" uses seems like a very effective solution. What do you do if you have many more unique shapes? There seems to be a limit to what can be shown in that layout example you shared
                      Subpath @Boldline
                      @Boldline said in trapezoid:
                      The maximum of that storage fields visible on the screen are 12, on my iPad Pro 12.9.
                      The maximum number of shapes is higher because you can switch between different libraries.
                      For architecture, electronics, shoes, faces, etc.
                      Since scrolling on the iPad is fast and smooth, scrolling back and forth isn't
                      much of a problem
                      Saving a shape only takes one click,
                      also just one click to place a shape on the canvas (or drag & drop).
                      So using this shape storage is also pretty fluid.
                      • B Offline
                        B-Vs-V @Subpath
                        @Subpath I could be mistaken, but isn't that also the case for the Affinity suite (assets)?
                          I'm creating a thread in " Features and Ideas. " on this topic,
                          because it is a bit more extensive as I thought.
                          So, my Post about a Shape Library is now in "Features and Ideas"
                          Here the Link:
                          https://www.vectorstyler.com/forum/topic/3878/kind-of-shape-library
                            Subpath @B-Vs-V
                            @Pat
                            I think there are some similarities.
                              861475_VctSt @VectorStyler
                              I am sure everyone agrees on how to draw trapezoids using VS's advanced functionality.
                              I think that since there are "star" and "spiral" tools, there should be a "trapezoid" tool as well. I think this is a short-sighted idea.
                              I wonder if this kind of tool is already obsolete.
                              LIc. 0 OS10.15.8
                              LIc. 1 OS13.6.7
                              • L Offline
                                Li Xiao @VectorStyler
                                @VectorStyler It is necessary to add a tool that can generate precise irregular polygon shapes, including isosceles triangles, trapezoids, etc. This tool should allow parameterized inputs for different side lengths, angles, and other properties.
                                  @861475_VctSt , @Li-Xiao
                                  could the "Envelope Distortion" be helpful
                                  with this kind of Transformation ?
                                  See Video here
                                  • L Offline
                                    Li Xiao @Subpath
                                    @Subpath Thank you! I need to generate a correct triangle based on the known values of its three sides, as shown in the following diagram.
                                      Subpath @Li Xiao
                                      @Li-Xiao, your welcome
                                      looks like a CAD case to me ?
                                      • L Offline
                                        Li Xiao @Subpath
                                        @Subpath Yes, it is relatively easy to implement in CAD software. Apps like AI or CD have plugins available for generating such shapes.
