An issue with Contour Tool
When applying the contour effect to a object the other contour effects of other objects disappear, although they are still visible in the layers panel.
@FastVector said in An issue with Contour Tool:
Could not replicate this with a simple test. Could Control+R (on Windows) refresh help here?
If there is an example file where this occurs, please send it to this email: csraba at vectorstyler.com
Send you the file
@FastVector Got the file. Yes, there is some bug here, not yet clear what could cause it, but it can be replicated here also.
I will try to fix this as soon as possible.
