    Expanding the options for the Path Sketch Tool
    21 Posts 5 Posters 38.4k Views 4 Watching
    • P Offline
      pentool @Subpath
      @Subpath Could this be a Windows issue? Cuz I'm on a Mac and it works fine for me, too.
      • P Offline
        pentool
        See relevant docs:
        https://www.vectorstyler.com/documentation/shapes/pathsketch/#sketching-with-lines
          Subpath @pentool
          @pentool said in Expanding the options for the Path Sketch Tool:
          yes, thats my guess
          thanks for the Doc link, will take a look
            the docs say:
            ..The sketch cursor indicates the line (or curve) mode. ..
            i dont see a indicator
              VectorStyler @Subpath
              @Subpath I will get back on this later, added to the backlog.
                Subpath @VectorStyler
                No problem, just wanted to mention it.
                I don't need that at the moment.
                • P Offline
                  pentool
                  This is the sketch cursor:
                  And when you press TAB it turns into the crosshair which indicates you are in line drawing mode.
                  So the documentation is correct. The sketch cursor can be this or that depending on the mode.
                    Subpath @pentool
                    @pentool
                    thanks for mentioned it.
                    but i know that allready from @b77 gif-ani example
                    and if you look at my videos
                    take this one here
                    there is no such indicator, and also the line drawing mode
                    does not work on window or i miss a setting in Preferences
                      b77 @Subpath
                      @Subpath A shortcoming of Recordit is that it displays a pointer instead of the tool icon/indicator
                      when recording the screen, so even with the recording it is a bit difficult to know what happens there
                      on Windows. That's why I used Gifox for the recorded GIF above.
                      But now you explained that indeed the crosshairs cursor doesn't show up. 👍
                      Remains for the developer to test on Windows.
                        Subpath @b77
                        i use very often "ScreenToGif" to record my gif Animation
                        and use then Recordit to record that and publish it here,
                        (because Recordit refuse sometimes to upload the Anim)
                        so something like what you mentioned would not be the case i guess
                        but any way its not the record software problem
                        i think i can believe my eyes 🙂
                        seems there is a problem with VS on Windows with switching
                        to straight line mode.
                        Because we should not forget i get no straight lines
                        regardless of the pointer
                        • P Offline
                          pentool
                          A little off topic, but the reason I don't like those screen recorders is because they don't scale. If you have a big screen, it won't fit into a 13" laptop screen and have to scroll left/right/up/down sometimes to see what people are doing.
                            Subpath @pentool
                            Yes, your right a youtube video could be a better choice if you need
                            a full screen record. But often you need just a little area and its fast
                            and it get the job done.
                            (ScreenToGif is a 170 kB Tool 🙂 )
                            On window you could scale the contend of a browser a bit via Control Key
                            and the scroll wheel.
