    Expanding the options for the Path Sketch Tool
    21 Posts 5 Posters 38.4k Views 4 Watching
      b77 @Subpath
      @Subpath It's working here:
      alt text
      Could be that because the default objects have no stroke it
      makes it look like the straight line mode doesn't work?
        @b77 Thanks for that tip - it's working here. Glad it's already part of VS!
          Subpath @b77
          No, it doesn't work.
          In my understanding, if i switch to straight line mode via the
          TAB key the " Path sketch tool " should create only straight lines.
          But it doesnt. I get far better results if i set " Smoothness "
          to the max.
          See video here
          Is there any setting in Preferences which need to be set first ?
          Or does this not work on Windows ? (VS 1.1.100)
          • P Offline
            pentool @Subpath
            @Subpath Could this be a Windows issue? Cuz I'm on a Mac and it works fine for me, too.
            • P Offline
              pentool
              See relevant docs:
              https://www.vectorstyler.com/documentation/shapes/pathsketch/#sketching-with-lines
                Subpath @pentool
                @pentool said in Expanding the options for the Path Sketch Tool:
                yes, thats my guess
                thanks for the Doc link, will take a look
                  the docs say:
                  ..The sketch cursor indicates the line (or curve) mode. ..
                  i dont see a indicator
                    VectorStyler @Subpath
                    @Subpath I will get back on this later, added to the backlog.
                      Subpath @VectorStyler
                      No problem, just wanted to mention it.
                      I don't need that at the moment.
                      • P Offline
                        pentool
                        This is the sketch cursor:
                        And when you press TAB it turns into the crosshair which indicates you are in line drawing mode.
                        So the documentation is correct. The sketch cursor can be this or that depending on the mode.
                          Subpath @pentool
                          @pentool
                          thanks for mentioned it.
                          but i know that allready from @b77 gif-ani example
                          and if you look at my videos
                          take this one here
                          there is no such indicator, and also the line drawing mode
                          does not work on window or i miss a setting in Preferences
                            b77 @Subpath
                            @Subpath A shortcoming of Recordit is that it displays a pointer instead of the tool icon/indicator
                            when recording the screen, so even with the recording it is a bit difficult to know what happens there
                            on Windows. That's why I used Gifox for the recorded GIF above.
                            But now you explained that indeed the crosshairs cursor doesn't show up. 👍
                            Remains for the developer to test on Windows.
                              Subpath @b77
                              i use very often "ScreenToGif" to record my gif Animation
                              and use then Recordit to record that and publish it here,
                              (because Recordit refuse sometimes to upload the Anim)
                              so something like what you mentioned would not be the case i guess
                              but any way its not the record software problem
                              i think i can believe my eyes 🙂
                              seems there is a problem with VS on Windows with switching
                              to straight line mode.
                              Because we should not forget i get no straight lines
                              regardless of the pointer
                              • P Offline
                                pentool
                                A little off topic, but the reason I don't like those screen recorders is because they don't scale. If you have a big screen, it won't fit into a 13" laptop screen and have to scroll left/right/up/down sometimes to see what people are doing.
                                  Subpath @pentool
                                  Yes, your right a youtube video could be a better choice if you need
                                  a full screen record. But often you need just a little area and its fast
                                  and it get the job done.
                                  (ScreenToGif is a 170 kB Tool 🙂 )
                                  On window you could scale the contend of a browser a bit via Control Key
                                  and the scroll wheel.
