    Can't find the node
    20 Posts 3 Posters 14.1k Views 3 Watching
    • AyoA Offline
      Ayo
      And another one...
      How and where can I see the Stroke Width Position (indicator-1) occur?
      Aside
      When figuring out which node/indicator applies where concerning the Stroke Width Tool/Width Brush, I have a stuck application almost every time. The shape I use is a very basic line/curve. Nothing difficult.
        VectorStyler @Ayo
        @Ayo said in Can't find the node:
        Yes, this is a known issue, and has been also replicated here.
        A fix already exists and will be available in the next build (early next week).
        • AyoA Offline
          Ayo
          @VectorStyler said in Can't find the node:
          Ok, that about the behaviour.
          But my actual question was: how/where can I see the 'Stroke Width Position' shape? (correction: listed in Indicator Shapes)
            VectorStyler @Ayo
            In the stroke width editor tool, when a width node is selected.
            • AyoA Offline
              Ayo
              I get the:
              • Stoke Profile Marker
              • Stroke Profile Node
              • Stroke Width Node
                but the 'Stroke Width Position' does not appear. Whatever crazy shape I give. Not with the Stroke Width Tool nor in the Stroke Width Editor window.
              • AyoA Offline
                Ayo
                I get the:
                Stroke Profile Node
                Stroke Width Node
                In this 'Path Width' cluster I have two more that I cannot make visible.
                resume:
                Indicator Shapes
                • Stroke Width Position
                Indicator-1
                • Stroke Profile Editing Position Node
                • Stroke Profile Editing Outline
                can you direct me to these indicators?
                  VectorStyler @Ayo
                  Looks like this and the other got skipped in the stroke width tool. This is a bug.
                  Will get fixed ASAP.
                  • AyoA Offline
                    Ayo
                    More questions.
                    If you're tired of my questions, just say so.
                    This time the Collider Tool
                    1.
                    The Collider Node I assume is the node appearing at the collision point between two shapes. In Indicator Shapes I can change the Collider Node all I want but it has no effect. Remains a Tiny Circle.
                    2.
                    Which selection from Editing Options 1 should give the color and line settings for this node?
                    I'll trial and error the whole list but nothing has any effect.
                    Is this a bug?
                    b77B VectorStylerV 3 Replies Last reply Reply Quote 1
                      b77 @Ayo
                      @Ayo
                      1. Seems to be a bug.
                      2. If I select 'Collision Snapping Indicator' from the list in Prefs > Editing Options 1,
                        changing its color and stroke width works here.
                      • AyoA Offline
                        Ayo
                        @b77 said in Can't find the node:
                        That one has effect on the snapping target path.
                        Not the node.
                          b77 @Ayo
                          @Ayo You want the point where you grab the shape to be changed?
                          Not the point where it snaps to another shape?
                          • AyoA Offline
                            Ayo
                            I am looking for the line and fill controls for the 'Collider Node' from Indicator Shapes.
                              VectorStyler @Ayo
                              1. The Collider Node I assume is the node appearing at the collision point between two shapes. In Indicator Shapes I can change the Collider Node all I want but it has no effect. Remains a Tiny Circle.
                              Looks like a bug, added to the backlog.
                                VectorStyler @Ayo
                                This is now not in use anymore, as it is handled by a snapping indicator, will be removed.
                                1. Which selection from Editing Options 1 should give the color and line settings for this node?
                                This will be the "Collision Snapping Indicator"
