    Can't find the node
    20 Posts 3 Posters 14.1k Views 3 Watching
    • AyoA Offline
      Ayo
      Found, thanks
      Two more I can't find
      1. 'Transform Selection Active Node' (Editing Options 1) how do I get it displayed?
      2. Is the 'Selection Center Node' shape selector (Indicator Shapes) not working? I can alter the fill and line in 'Transform Selection Center' (Editing Options 1) but not the shape.
        VectorStyler @Ayo
        @Ayo said in Can't find the node:
        This one shows with the Collider tool, when hovering over the edge of a shape.
        1. Is the 'Transform Selection Center' shape selector (Indicator Shapes) not working?
        It works here, but the "Transform Selection Center" is a different thing and its shape cannot be selected.
        • AyoA Offline
          Ayo
          @VectorStyler said in Can't find the node:
          OK.
          But then; where and in what situation will I be able to see 'Transform Selection Center' indicator?
            VectorStyler @Ayo
            @Ayo This is shown at the center of the selected objects, when the Transform tool is used.
            Must be enabled from the toolbar with the 0_1686298005761_center.png icon
            Can be used to set the rotation pivot point.
            • AyoA Offline
              Ayo
              And another one...
              How and where can I see the Stroke Width Position (indicator-1) occur?
              Aside
              When figuring out which node/indicator applies where concerning the Stroke Width Tool/Width Brush, I have a stuck application almost every time. The shape I use is a very basic line/curve. Nothing difficult.
                VectorStyler @Ayo
                Yes, this is a known issue, and has been also replicated here.
                A fix already exists and will be available in the next build (early next week).
                • AyoA Offline
                  Ayo
                  Ok, that about the behaviour.
                  But my actual question was: how/where can I see the 'Stroke Width Position' shape? (correction: listed in Indicator Shapes)
                    VectorStyler @Ayo
                    In the stroke width editor tool, when a width node is selected.
                    • AyoA Offline
                      Ayo
                      I get the:
                      • Stoke Profile Marker
                      • Stroke Profile Node
                      • Stroke Width Node
                        but the 'Stroke Width Position' does not appear. Whatever crazy shape I give. Not with the Stroke Width Tool nor in the Stroke Width Editor window.
                      • AyoA Offline
                        Ayo
                        I get the:
                        Stroke Profile Node
                        Stroke Width Node
                        In this 'Path Width' cluster I have two more that I cannot make visible.
                        resume:
                        Indicator Shapes
                        • Stroke Width Position
                        Indicator-1
                        • Stroke Profile Editing Position Node
                        • Stroke Profile Editing Outline
                        can you direct me to these indicators?
                          VectorStyler @Ayo
                          Looks like this and the other got skipped in the stroke width tool. This is a bug.
                          Will get fixed ASAP.
                          • AyoA Offline
                            Ayo
                            More questions.
                            If you're tired of my questions, just say so.
                            This time the Collider Tool
                            1.
                            The Collider Node I assume is the node appearing at the collision point between two shapes. In Indicator Shapes I can change the Collider Node all I want but it has no effect. Remains a Tiny Circle.
                            2.
                            Which selection from Editing Options 1 should give the color and line settings for this node?
                            I'll trial and error the whole list but nothing has any effect.
                            Is this a bug?
                            b77B VectorStylerV 3 Replies Last reply Reply Quote 1
                              b77 @Ayo
                              @Ayo
                              1. Seems to be a bug.
                              2. If I select 'Collision Snapping Indicator' from the list in Prefs > Editing Options 1,
                                changing its color and stroke width works here.
                              • AyoA Offline
                                Ayo
                                @b77 said in Can't find the node:
                                That one has effect on the snapping target path.
                                Not the node.
                                  b77 @Ayo
                                  @Ayo You want the point where you grab the shape to be changed?
                                  Not the point where it snaps to another shape?
                                  • AyoA Offline
                                    Ayo
                                    I am looking for the line and fill controls for the 'Collider Node' from Indicator Shapes.
                                      VectorStyler @Ayo
                                      1. The Collider Node I assume is the node appearing at the collision point between two shapes. In Indicator Shapes I can change the Collider Node all I want but it has no effect. Remains a Tiny Circle.
                                      Looks like a bug, added to the backlog.
                                        VectorStyler @Ayo
                                        This is now not in use anymore, as it is handled by a snapping indicator, will be removed.
                                        1. Which selection from Editing Options 1 should give the color and line settings for this node?
                                        This will be the "Collision Snapping Indicator"
