Setting to adjust right and left mouse click to determine what controls fill and stroke?
Recently the default setting for clicking on swatches in additional open palettes will now always make the left mouse click be the fill and the right mouse click be the stroke. Is there an option still to set it back to the right click being whatever is in the background and left click is the foreground option in the color select? Right now the main palette that loads with VS has it set that way and not the former and so it gets a little confusing when I switch between my default palette and the additional ones, such as the sidebar palette.
@Boldline No setting is available for this. The main issue is that the color palette bar does not have the fill/stroke mode switching knob.
It does link to the fill/stroke mode of the color and palette panel, but this is disabled for now, as it was causing confusion.Should there be a settings for this?
@VectorStyler Only speaking for myself, I liked the way I could use right click to change the color of the background color swatch and use the left mouse button to click the foreground color - seemed to work with any palette colors were pulled from.
A few months back @encart and maybe a few others wanted a way to consistently make all right clicks define the stroke and all left clicks define the fill, regardless of what was happening in the two square color swatch panel. So I understand their request but I was having a hard time adjusting to that method.
Right now for example, in the main loaded palette, it works like I first described (left click sets foreground color) and in the added palette bar, it works the other way (left click defines fill color) - this is where it gets confusing because I have to remember to use it differently based on where I grab a color from.
A
