    Transform/rotate after blending, weird behaviour or crashes VS
    17 Posts 5 Posters 24.9k Views 4 Watching
      Boldline @B-Vs-V
      @PatrickM I know if you record the steps you make with a video of the screen and if you save the file and send it over to @VectorStyler , those things help expedite the fixes
      • S Online
        Subpath @B-Vs-V
        @PatrickM
        all fine here and no problem
        VS 1.1065
          b77 @B-Vs-V
          @PatrickM It looks like one of the two circles is flipped horizontally.
          Check this value here in the Transform panel and if it has a minus, delete it:
            VectorStyler @B-Vs-V
            @PatrickM Could be that they were scaled or rotated? What is the node editor showing when the start / end is selected?
            Send me the file with that blend, I will try to figure out what could cause this.
            • S Online
              Subpath @b77
              @b77 said in Transform/rotate after blending, weird behaviour or crashes VS:
              like @b77 wrote, it looks here like @PatrickM Result
              if a Circle was horizontally flipped in my Test
              the Circle on the right side.
              rotate a circle looks different
              • B Offline
                B-Vs-V @VectorStyler
                @VectorStyler It seems to have been a temporary issue just after the installation of v.065.
                @b77 & @Subpath It was indeed that unintended mirroring problem. I haven't managed to reproduce it yet and everything is as expected now.
                @Boldline This is what I usually do and will do if I reproduce the problem.
                Thanks to all!
                • B Offline
                  @VectorStyler It is much better with v.065 ; no crash so far and expected pattern design.
                  Well, it is only a quick test and it is virtually nothing of interest as pattern but to show you that we can start to get patterns:
                  • with "copy",
                  • with "clone" however, I've got an interesting pattern but totally unexpected with respect to colours; I've just changed one colour (blue) of the gradient & I've got this multicoloured design â˜ș
                    @Pat This issue should be fixed in build 1.1.072
                    • B Offline
                      @VectorStyler There are still some issues with the "clone" feature of blended objects (0.075 ; W10 & W11).
                        @Pat said in Transform/rotate after blending, weird behaviour or crashes VS:
                        @Pat email me an example where this occurs
                        • B Offline
                          @VectorStyler You can test on all the files I sent you including the one from last week. Just use the Object-Transform-Transform/Rotate feature(s) with 'clone' and you will finally get the issues. Just compare with 'Copy' where all the object changes are done correctly. Thanks.
