    Transform/rotate after blending, weird behaviour or crashes VS
    17 Posts 5 Posters 24.9k Views 4 Watching
    • B Offline
      B-Vs-V @VectorStyler
      @VectorStyler The file has been sent ☺
      • B Offline
        @VectorStyler Just wondering, I did a blend between circles and therefore I should expect only circles as before. But I get this and I don't know why since I did as usual:
        BoldlineB S b77B VectorStylerV 4 Replies Last reply Reply Quote 1
          Boldline @B-Vs-V
          @PatrickM I know if you record the steps you make with a video of the screen and if you save the file and send it over to @VectorStyler , those things help expedite the fixes
          • S Online
            Subpath @B-Vs-V
            @PatrickM
            all fine here and no problem
            VS 1.1065
              b77 @B-Vs-V
              @PatrickM It looks like one of the two circles is flipped horizontally.
              Check this value here in the Transform panel and if it has a minus, delete it:
                VectorStyler @B-Vs-V
                @PatrickM Could be that they were scaled or rotated? What is the node editor showing when the start / end is selected?
                Send me the file with that blend, I will try to figure out what could cause this.
                • S Online
                  Subpath @b77
                  @b77 said in Transform/rotate after blending, weird behaviour or crashes VS:
                  like @b77 wrote, it looks here like @PatrickM Result
                  if a Circle was horizontally flipped in my Test
                  the Circle on the right side.
                  rotate a circle looks different
                  • B Offline
                    @VectorStyler It seems to have been a temporary issue just after the installation of v.065.
                    @b77 & @Subpath It was indeed that unintended mirroring problem. I haven't managed to reproduce it yet and everything is as expected now.
                    @Boldline This is what I usually do and will do if I reproduce the problem.
                    Thanks to all!
                    • B Offline
                      @VectorStyler It is much better with v.065 ; no crash so far and expected pattern design.
                      Well, it is only a quick test and it is virtually nothing of interest as pattern but to show you that we can start to get patterns:
                      • with "copy",
                      • with "clone" however, I've got an interesting pattern but totally unexpected with respect to colours; I've just changed one colour (blue) of the gradient & I've got this multicoloured design ☺
                        @Pat This issue should be fixed in build 1.1.072
                        • B Offline
                          @VectorStyler There are still some issues with the "clone" feature of blended objects (0.075 ; W10 & W11).
                            @Pat said in Transform/rotate after blending, weird behaviour or crashes VS:
                            @Pat email me an example where this occurs
                            • B Offline
                              @VectorStyler You can test on all the files I sent you including the one from last week. Just use the Object-Transform-Transform/Rotate feature(s) with 'clone' and you will finally get the issues. Just compare with 'Copy' where all the object changes are done correctly. Thanks.
