Performance issues with vector editing
Welcome @Bones
just an info, because you mentioned ClipStudio Paint, you can copy
vector graphics from CSP via "Copy as SVG" over clipboard
into VectorStyler.The other way around is also possible, in VS set Preferences > Performance > Copy as SVG.
Unfortunately here there are some restrictions which are CSP related.In this thread (belowe the middle) you can find examples
https://www.vectorstyler.com/forum/topic/1946/perspective-tool/15
Hi @Bones
Looks like you have read this book, eh?
Vector Basic Training: A Systematic Creative Process for Building Precision Vector Artwork
@Ingolf said in Performance issues with vector editing:
Hi @Bones
Vector Basic Training: A Systematic Creative Process for Building Precision Vector ArtworkIndeed! I used it in Illustrator classes that I taught until a few years ago. I still recommend it to this day to anyone starting out or wishing to improve their curve control. One-in-a-kind book on the subject in my opinion.
@Subpath Thanks for the tip.
Tried it in ClipStudio Paint, and it works. I also attempted to copy SVG from / to PhotoLine, but that doesn't work as well. Copy from PL to SV works, but not the other way around.
I use PhotoLine as my main image editor/hub, and PhotoLine includes a feature for a round-trip workflow for sending layers to another design app. It works fine with Inkscape, but unfortunately not (yet?) with Vectorstyler.
Is it possible to save directly to SVG from Vectorstyler and overwrite the original SVG file without the interruption of an export dialog?
@Bones said in Performance issues with vector editing:
Indeed! I used it in Illustrator classes that I taught until a few years ago. I still recommend it to this day to anyone starting out or wishing to improve their curve control. One-in-a-kind book on the subject in my opinion.Fascinating! It's one of those old world books that shows what the old world could do. A writer and creative who is not only skilled, but methodical in a clear-eyed way. And who can even explain himself, simply.
I don't have many physical non-fiction books on my otherwise large bookshelf because so few, so useful, have been written.
@Ingolf Agreed!
I do still teach other classes once in a while, and when I see students work on their Illustrator assignments I always sigh to myself. Not because their design thinking is questionable (it generally isn't) but because the quality of their curve work is.
A quick explanation of the clockwork method helps them on their way.
Most students start designing on the screen with a mouse. I never understood that: I either start sketching on paper or on a tablet/cintiq/wacom. At least a few students use a tablet with pen nowadays - and those students tend to produce the better work
Another reason why I like Von's book: he starts on paper.
Hello, first post of mine!
The existenceof Vectorstyler was pointed out to me via the Affinity forums. The feature list was intriguing to me, and I decided to give Vectorstyler a whirl.And welcome! You will feel at home here, this is a more focused forum without fuss and noise, and thank you for your initial and thorough feedback.
I've actually experienced slower performance myself in a few test documents, but so far nothing that has affected my real work. It's on my list of topics to report in here, but I'm dripping bug reports in priority order, and performance I'd report once I've made a real life document that can be used as documentation.
We've kept @vectorstyler very busy and well entertained over the last few years with many, many bug reports and feature requests, many of which have been fixed. So it's really self-help to actively report bugs or issues; it actually fixes them for the benefit of oneself or everyone. As you have now experienced yourself, your feedback is listened to promptly and seriously.
There's a lot really built up and into Vectorstyler, so I'm probably going to recommend @VectorStyler to spend some months or so on optimizations centrally in the engine room, but it's really something that requires knowing the needs and real use of the customers. But at some point, people throw up posters like the one from the book. And more complex than that.
I myself have stopped throwing complex test documents into programs, and instead test them with my own projects and workflows, it gives a more accurate picture of whether I like the programs and whether they do what I need them to do. It also gives me a better idea of the background to the bugs I'm reporting.
And most importantly, I guess, customers' real production problems are solved.
You've come into Vectorstylers life relatively early, so there will be bugs to fix and implementations to improve or redesign along the way. As mentioned, active participation is beneficial, and bug fixes are released regularly. In 2022 alone, Vectorstyler has become noticeably better and more beautiful, thanks to everyone in here, and especially thanks to the most active and listening developer on the planet.
You can see what's in the pipeline here:
https://www.vectorstyler.com/roadmap/
I am not sure, but I think no.
Whereas I don't really see the export panel as a hindrance.
Because once you set your export format, it stays set.
Then it is enough to confirm it with the Enter key when it appears.
I assume Inkscape uses .SVG to exchange data via clipboard.Then, i think, exchange data via clipboard from VS to PL should also
work, if you set at "Performance", "Copy as SVG" in VS Preferences.
Yes. Export first with the regular export dialog (selecting all the options).
Then save the VS file also (last export settings are stored in the file).Then the File -> Export Again can repeat the last export (with all the settings and the file name), even when the file is reopened later.
@Bones The AI and SVG importing issues will be fixed in the next build.
About the adjustment layer with blur issue: does this occur in the Wormwood example, or is it slow also with some simple vectors?
@VectorStyler said in Performance issues with vector editing:
That's a very quick response indeed! Don't you take a break over the holidays?
The slowdown with adjustment layers occurs with slightly more complex projects. I tried another file which isn't nearly as involved as the Wormwood one, and it still struggles.
As I said, even the Wormwood example is fine in other design apps when adjustment layers are used (although Illy cheats by decreasing the resolution of the effect while editing).
@Bones The AI and SVG importing issues should be fixed in build 1.1.072.
There should be some performance improvement also, when dragging objects.Setting the thread count values to too large might not always help. Also try with smaller values, like 8 or 12 for that config.
The overlapping gradient mesh issues will be fixed later.
The newest build loads the SVG file quickly and correctly! Quite impressed with that improvement: classy!
The AI file also works much better, albeit that the textures are missing.
Dragging performance works a little better as long as the user is zoomed in somewhat. Zoomed out it still is very slow. Is that because of the anti-aliasing?
Is there a way to turn off anti-aliasing in VectorStyler?
Perhaps a performance trick would be to turn off anti-aliasing when curves and objects are edited for the layers that are being worked on?For example, in PhotoLine the anti-aliasing may be turned off globally, and it increases editing performance by around 200-300%.
For changing anti-aliasing options in VS
take a look under
View > Subpixel
@Bones Anti-aliasing can be turned off using View -> Subpixel -> None.
But it has only a small impact on redraw performance.
At what zoom level was this slowdown observed? and is it with the AI import or the SVG (results are different).
As for the AI file: some features are not (yet) supported, there will be improvement in the future.
