    Stroke width tool defaults to zero width using stylus
    5 Posts 3 Posters 5.0k Views 2 Watching
      Using the stylus, when I add a node using the stroke width tool, it defaults to a zero width automatically.
      0_1671304303108_de03b35c-c3c7-4718-a187-8205cffce312-CleanShot 2022-12-17 at 14.03.34.png
      0_1671305634151_path width issue.vstyler
        Subpath @Boldline
        thats with the Mouse also
        seems like the normal behavior in VS
        i guess the reason for this is that you are close
        to underlying Middle Curve and this define
        the width of the Stroke for that moment when you
        set a point
        my solution is:
        when i set a Point i keep holding the Mouse Button down (eg the Pen)
        and slide the Mouse away from that middle Curve this will change the Stroke width
          Boldline @Subpath
          @Subpath Thanks for checking that as well. I understand the way you do it by not letting go and pulling immediately to avoid the issue. I would think it would be better if you were to click and release, for it to do nothing at all rather than set the width to zero like that. when you click - especially because it becomes really difficult to pull the handles to widen the width when it's in that position.
            @Boldline Added this to the backlog. I think it might depend on which side of the stroke the node is dragged towards.
              I'm posting here some finds I found while experimenting
              with the Width Tools a while ago. Maybe it is helpful for you
              or anybody else.
              See this Video here
              this is just a pic from the video
              with the Stroke Width Panel on the left
