How to apply effects to other objects?
 @Pat @VectorStyler mentioned allready the Tools that could be helpful. Just my 2 cents. I like to use the Picker Tools for that.
 Style Picker for Gradient.
 Shape Effect Picker for the Offset Effect.
 Select the Object you like want tranfer the change to
 and pick the Effect from Object wich have the Effect allready.Btw, if you use any of that Picker Tools, you could temporaly
 switch to the "Transform" Tool by holding the Ctrl (Win) / Command (Mac) Key down.
 This is helpful for faster Object selection if you have many Objects.
 @Pat I will try to replicate this on Windows.
 @Subpath Thanks. Yes of course, I first select the shape to modify and I then use the picker tool... but since nothing works, I did try everything  @VectorStyler I'll send you the file
 @VectorStyler said in How to apply effects to other objects?: @Pat I will try to replicate this on Windows. i tryed it allready on Win 10
 and everthing works as expected
 Used Shape Effect Picker for Offset Effect
 and Styler Picker for Gradient.
 @VectorStyler I think there is still enough space to get sharp pointed edges but no way by modulating the miter limit... another way ? Thanks.
 @Subpath maybe different due to the offset path setup ? I've tried many times but to no avail. @VectorStyler also, when I want to change the stroke profil through the offset path, it didn't.
 @VectorStyler When I tried to apply an offset path to several shapes, VS crashed. A crash report has been sent.
 @VectorStyler reproducible when I click on "preview"
 @VectorStyler Well, I don't see the way to save the offset path I did into a Shape effects... but never did & then I may be out of the road here
 @VectorStyler No way... 3rd crash reports. Hope they help finding the bug.
 @VectorStyler file sent
 @Pat said in How to apply effects to other objects?: I think there is still enough space to get sharp pointed edges but no way by modulating the miter limit... another way ? Set the Miter Limit value to very small (5 or less).
 @VectorStyler I've tried all the possible values
 @Pat Got the crash reports, I will try to replicate this issue.
 @VectorStyler you should have got the file too.
 @Pat Yes, I have the file. But could not replicate the crash yet. Maybe a short recording would help: to know precisely what to select, and how much offset to try.
 @VectorStyler just click preview after having selected a few shapes on the left
 @Pat Is the offset created with the "Object -> Shape -> Offset Path" or with the "Effects -> Outline -> Offset Path" ? Only these have a "preview"
 @VectorStyler Object -> Shape -> Offset Path
 @Pat What values are in the "Distance" and "Steps" field?
