How does arithmetic operations work in Transform panel?
In Transform panel, basic arithmetic operations like +, -, *, /, for move, dimension or scaling doesn't work as expected.
Skewing and rotating seem to work well.
in Transform panel
@Harry The [mm] gets in the way. Delete [mm] and then add +10
@VectorStyler said in How does arithmetic operations work in Transform panel?:
Tried this already - when I delete [mm} and add +10 the result is in [meters]
But your method works for scaling.
P.S. Do we always have to delete units? For degrees like skewing and rotation basic arithmetic operations work well.
@Harry said in How does arithmetic operations work in Transform panel?:
I meant work well without deleting units
@Harry In the angle editor the units are just decorative.
In the position / size the units always convert to [pt] and this causes the issues here.
I will try to improve this.
