Arc tool?
I was looking at the updates in Amadine and that revived my curiosity about adding a dedicated arc tool to VS. @b77 had some good ideas in the linked thread from earlier this year for making an arc using the parametric ellipse tool - and I do like the ability to choose between a pie or an arc by placing your cursor on either side of the line.
VS is certainly an advanced vector styling program - I wonder how many things should be added that might help bridge the gap between power user and standard user. would an arc tool be a helpful inclusion? I think it would be a solid addition to the pen tool set in the vertical toolbar and not take up too much space or overwhelm people.On a related note, I've also been thinking about the potential of adding pre-made curves - for example a perfect "s" shape curve, maybe including the golden ratio? I'm thinking of things that are not the easiest to create or could be used frequently.
Using a special arc tool would be faster than editing an ellipse shape.
Maybe it should be added as a shape variation of the ellipse.Regarding pre-made shapes, I guess this will be easy to do after plugin support is implemented.
@Boldline I can add this to the backlog of features. Having an arc tool is easy to implement, but from what I see in AI, these arcs are always set at 90 degree.
Yes, if we need parametric shapes. Otherwise, just create shape presets and drag and drop onto a document. Maybe we need a tool that can "draw" a shape from the shape presets (or style).
I was thinking having these as templates in VS could be a helpful thing - maybe stored under the "guides" section? editable guides that could be turned on for a document. I pulled these from the amadine site but they were what I was already imagining as defaults.
Using the rule of thirds:
The Golden Ratio:
Golden triangle composition:
Wouldn't this make more sense as a pen tool section addition? or were you thinking of adding parametric options to the arc and therefore place it with the other parametric shape options?
@VectorStyler said in Arc tool?:
I think this would be awesome.
I'd like to see them be available for 180 degrees as well
