    Can Stroke width increment shortcuts start at 1 pt for non-expanded shapes?
    5 Posts 2 Posters 5.1k Views 1 Watching
      I see the improvement made in build 61 for increment shortcuts to start at 1 pt. Can the same be done with non-expanded shapes? Keep things consistent?
        @Boldline said in Can Stroke width increment shortcuts start at 1 pt for non-expanded shapes?:
        Not sure I get this. It should work for any shape.
          @VectorStyler I'm not sure if I am missing something - before when I was testing out this new adjustment, it was increasing the stroke width increment by 1pt and starting at 1 pt so long as the shape was converted to curves first. It was jumping to 2pt if I tried on a shape that I had yet to convert to curves. This happened even after restarting VS.
          A few hours later, with a fresh opening of VS again, I tried again and this time both the shapes before and after converting to curves start with 2pt when using the bracket key...
          I'm not sure if its me or what!
            @Boldline This can be replicated here, must be a bug.
              @Boldline This issue should be fixed in build 1.1.062
