How to best install repeater presets
What is the best way to install custom repeater presets into VS? I downloaded the set that @Dazmondo graciously shared but was unable to figure out the best way to install them. My attempt to do so did not seem to work
@Boldline When working with custom presets, and also to avoid erasing them if the app is reset do as follows:
- create a folder for these presets.
- copy custom preset files here.
- in the Styles -> Preset Manager select Create Group.
- set a name and select the folder and confirm.
Now files added to that user folder are shown as presets.
@VectorStyler Thank you for laying that out in easy to follow steps - I will try that and get back to you fi I have any issues
@Boldline BTW: the above steps work only if the file name matches the preset type name (i.e. it is not an "exported" preset).
Otherwise, it will be required to import it.
Nevertheless, it is good to have custom preset folders / groups.
@VectorStyler Should I be setting up different preset folders for each major tool? or one preset folder with sub folders?
@Boldline One preset folder, no sub folders.
But other preset folders can be added as separate preset groups.
