    Repeater halftone problem on rasters
    56 Posts 5 Posters 138.3k Views 4 Watching
      @Boldline Oh, I thought you were dealing with vector objects, not bitmaps.
      If it's monochrome, why do you need separations?
        There are some small changes to repeaters. Editing the Intensity of the Object Content scaling mode allows now the selection of a color mode and color channel to be used as the intensity source.
          @Boldline In any case, you can change the color mode of the bitmap to Grayscale from Effects > Adjust Colors > Color Mode.
            @b77 said in Repeater halftone problem on rasters:
            Sorry for the confusion. In this case it's a raster image that I wanted to convert to a white screen and a gray screen with halftones. The white would not be halftoned. I wanted to see if this was possible in VS
            Based on your thinking, How else would I did the separations?
              @Boldline You can try vectorizing it and selecting only the white resulting objects that make the sprayed area (Select > Select by > Fill…), group them and give it a Pantone Translucent White, then convert a copy of the bitmap itself to Grayscale and use that for Repeater.
              Other than that, since VS doesn't do bitmap masking, this would require an image editor like Photoshop or PhotoPaint which can do the needed masking and conversion to duotone (made of two Pantones).
              • DazmondoD Offline
                Dazmondo @b77
                @Boldline said in Repeater halftone problem on rasters:
                Just saw this last night and woke up thinking about how to approach this. I'm not sure if this is exactly what you want to achieve Boldline but heres a Vid-grab of how I'd tackle this, now I've got my head around repeater: https://drive.google.com/file/d/1cWbX3VjoKbr5FrhFsbnHSv4Bi_R01Dwv/view?usp=sharing
                Excuse the poor video quality Vimeo won't let me upload now unless I start a PLAN (hate that word) so it's back to google drive
                I have come across a few problems (maybe bugs) with the ruler guides not respecting Top-down coordinates and also the gradient mask tool flitting to the wrong place
                DazmondoD 1 Reply Last reply Reply Quote 2
                • DazmondoD Offline
                  Dazmondo @Dazmondo
                  Further to the above - thought I'd have a quick go with the ref image in the post and it all seems straight froward, although VS tracing is not as good as ImageVectorizer (which I would normally use) Really great that we can now access the symbol which is repeated in Raster work without having to create a symbol from scratch👍
                  :0_1660213248991_Screen Grab 2022-08-11 at 11.16.02 am.png
                  Heres the VS file:0_1660213362622_Halftone beard.vstyler
                  • DazmondoD Offline
                    Dazmondo @Dazmondo
                    @Dazmondo Separates great:
                    2_1660214581370_Screen Grab 2022-08-11 at 11.39.09 am.png 1_1660214581370_Screen Grab 2022-08-11 at 11.39.37 am.png 0_1660214581370_Screen Grab 2022-08-11 at 11.40.06 am.png
                    DazmondoD 1 Reply Last reply Reply Quote 4
                    • DazmondoD Offline
                      Dazmondo @Dazmondo
                      @Dazmondo For a two colour job I would prob pick out a bit of highlights and colour up White to give a touch more contrast - would probably look better with an high res pic:
                        Boldline @Dazmondo
                        @Dazmondo WOW! thank you for helping with this. I do have a slightly improved copy of the design I got from the client. I had also upscaled that image and adjusted the ppi. I was getting stuck in the repeater so I will check out the video and see how it goes - thank you for the help! this is an awesome development
                        • DazmondoD Offline
                          Dazmondo @Boldline
                          No worries boss - I don't have a lot of work on at the moment, so kind of a pleasure to learn via experiment.
                          Here's my repeater presets if it's any help? I always tend to use Half Intense or Halftone Intensity and theres maybe a few other options thats part of these presets that I should maybe get around to ditching
                          https://drive.google.com/file/d/1wd9hMngTJXi0gYY1uSOpN4uxaq6F7W6e/view?usp=sharing
                            @Boldline , @Dazmondo
                            I just like to tell that i found a way to get a Halftone Line like Result in VS.
                            Edited:
                            Part 4 is now online an will be found here
                            ...a kind of halftone Lines, Part 4
                            Here a Example
                              As a Request from Boldline.
                              I find two old Files, which you can download here
                              0_1759495641507_Repeater-Structures-1.vstyler
                              0_1759495651912_Repeater-Structures-2.vstyler
                                Boldline @Subpath
                                @Subpath Thanks! I appreciate you digging those up. I will take a look at them in detail later today. Sometimes it helps me to see a working example and then I can reverse engineer it and learn from it to make my own creations. I appreciate your examples and tutorials and what you contribute to the forum.
                                These were some of the ideas I saw online that I wanted to be able to imitate with the repeater tool
                                  Subpath @Boldline
                                  Thanks too, I feel the same way; learning through reverse engineering is very helpful.
                                  Interesting designs. I think Repeater still has a lot to offer. 🙂
                                  What I like about it is that you can use symbols, repeat them, and still continue editing.
