How do I update live fonts if I activate them after file is open already?
If I open a file that has missing fonts and do not update them at the missing fonts prompt, but then later activate the font in my font manager program, how would I update the fonts in the file?
@Boldline Try Text -> Replace Fonts
@Boldline In the Mode drop down, select "Missing"
@VectorStyler Thank you - that worked well except that when after opening the replace text panel and activating the missing fonts and then clicking ok - the old fonts remained. I had to reopen the same replace fonts panel and press ok again and then it updated the document with the correct fonts. Is that normal?
@Boldline said in How do I update live fonts if I activate them after file is open already?:
Is this the Replace Font view?
If so, this does not sound normal.
One the missing fonts are replaced, opening the Replace Fonts view again should have an empty list for the Missing mode.
