Some Distortion tools not working
@Dazmondo
Seems to be working here
@Dazmondo said in Some Distortion tools not working:
Heres the example from the vid
It is working here also. But one observation, that might be an issue: selecting the effect tool from the toolbox will add a new effect if it does not match the already added effect.
Also: select the object and in the Shape Effects panel click the second icon at the bottom. This activates the shape effect editor for the selected effect.
@VectorStyler Damn ---- heres another vid: https://drive.google.com/file/d/1N4Flbov1s7s88hdBz9No776AhrH1ewzW/view?usp=sharing
There seems to be some issue with showing and updating the handles in those editors. I added this to the backlog.
EDIT: try a Command+R for refresh / update if the handles are off.
@VectorStyler Could be some glitch related to some setting in @Dazmondo 's Preferences.
@b77 said in Some Distortion tools not working:
Yes, it could be. But I would need the settings file to see that.
@Dazmondo Switch to Finder > click the 'Go' menu > Go to Folderβ¦
Paste this:
~/Library/Application Support/NumericPath/VectorStyler1.0/vector/data/resources
Hit Enter.
Send the two files (settings.xml and workspace.xml) to the developer.
@VectorStyler said in Some Distortion tools not working:
I've found the problem: For some unknown reason Direct preview of changes was unticked --- now ticked and working as normal
@Dazmondo Just found the same here.
Thanks guys
Ok, but this could also be a bug. When the mouse is released, the effect should apply.
Yes, now I can replicate and it is a bug.
The next bug fix build release is hereby dedicated to @Dazmondo for the numerous recent Bug discoveries both intentional and the inadvertent!
Special thanks to @VectorStyler for hitting clean-up
