Importing images in different color modes than the document's color settings
Since there are many combination patterns, I have not tried all of them, but similar results are expected.
(Example A)
Document settings:
Color: CMYK
CMYK: Japan color 2001 coated
Intent: RelativeImport image
Color: RGB
Profile: Adbe RGB (1998)Early symptoms
The import area looks black.(Example B)
Document settings:
color: RGB
RGB: Adobe RGB (1998)
color: CMYK
profile: Japan color2001 coateddEarly symptoms
The import area looks transparent.(Example C)
Document settings:
color: CMYK
color: RGB (1998)
profile: TIFFEarly symptoms
(It's confirmed)
Should I set "Full Disk Access"?
Is there a plan to check the properties of imported images with VS?
If possible, I want it.
@861475_VctSt Yes there is a plan to import and use the color profile of the image. This is treated as a bug.
You can enable Full Disk Access for now as a workaround for reveling in finder.
sorry. It was a mistake in expression.
It is a function to see the outline of the imported graphic as "document information" in VS.
@861475_VctSt This one is not clear.
Is this about showing information about the imported image, line width, height, color mode, profile etc? And where to show this info?Maybe an example of what this feature should be would help.
That's right.
For example, I wish I could see it in the "Content Link" panel.This allows us to check for images that are data inappropriate for import and reprocess if necessary.
For example, in Adobe Illustrator
Document Information Panel> Link Information
@861475_VctSt Got it. Thanks!
@861475_VctSt and @vectoradmin
To me it's important to see the DPI value of a bitmap image after it's been imported in the document, so I can know if it's good enough for print and resize it or⦠use something else.
Would displaying the DPI value of the selected bitmap at the head of the context panel be difficult do implement? Currently when you select a bitmap you see just '{Image}' displayed there. Not very informative.
(When you scale down the image on the canvas, the DPI would increase, and if you scale it up it would decrease).
@b77 I think this is easy to implement, but it will not make it into the next build (for this week). It will be implemented in the build of next week.
@vectoradmin Great! I wanted to suggest this a long time ago.
I have confirmed the improvement.
Furthermore, it is preferable that the "embedded color profile" is also displayed.
Expectations continue.
@861475_VctSt Opened a new task in the backlog on importing embedded color profile of the image.
I checked the "color profile" display.
A small but very useful feature for us.
Thanks
