Black in CMYK profile is not black
@plrang Oh, I know what you mean — an option to display plain black as darkest black — and I don't think that is available. The developer might correct me.
Rich Black means four plates instead of one if you print, so…
@b77 OK, generally it is not a big problem, I can partially design in VS and transfer to Affinity. Thank you.
@plrang Appearance of black is important — I'm sure the developer will consider offering this option.
@plrang What was the CMYK color profile used in Affinity and in VS?
@VectorStyler CMYK/8 Web Coated v2 both.
@plrang I think VS needs a "Rich Black" option.
@VectorStyler This is how I see it.
@plrang I will try to replicate this with the color profile. What is the Display (RGB) profile used in Affinity and VS?
@VectorStyler Both use the same sRGB ...966 2.1
Please let me add this.
It is extremely important that the software (can) only displays rich black but not automatically output it!In a normal prepress workflow you'll want to see when (and where) a normal black has been used especially when mixed with other rich black elements. There are tons of reasons why a pure black element must stay pure black in output.
So if you're going to implement this, make sure that display and output of rich blacks are optionals.
Thanks!
@Torakikiii said in Black in CMYK profile is not black:
Will do so.
